help needed backhoe
bignate
07-30-2003 20:26:01
my john deere 310D backhoe will not move it runs and everything u hear no grinding of metal when u put it in gear or the motor does not die someone tell me whats wrong
Fred Peck
02-06-2006 10:02:08
 Re: help needed backhoe in reply to bignate, 07-30-2003 20:26:01
We have the same problem with our backhoe. We found that we could shake the front bucket and it will sometimes move. We think we have it narrowed down to the park brake switch not working properly. We have ordered one and will find out in a day or two. Our backhoe is a 1992 310D.
Bill
09-01-2003 23:15:37
Please let us know if you have resolved this issue... We have the same problem, and we are so lost. We do not have a clue as to what is wrong. We have a JD 310D, and after driving forward, we shifted into N then reverse... It would not move, so we tried putting it back in first. The stupid thing still will not move. We have fluid in the XMSN, it is not really pretty and new, but it is full. We also have tried disconnecting the two switches on the levers. It happened all of a sudden, no grinding, no chattering, nothing.... It just broke and will not move. Folks I am not one to begg, but I am desperate for some advice... Any easy to find or test things that are inexpensive. The backhoe is mainly for hobby, but it definitely has a payment.
Please help us to resolve our issue.
Thank You so very much.
Jonathan
07-31-2003 03:27:19
There is a clutch disconnect swith on the transmission shift lever...also there is one on the top of the loader valve lever. Make sure the button on one of them is not stuck in or the switch is defective. You can disconnect the switches to eliminate them as a problem. Did this happen all at once ??? or was it gradual ?
davidval
07-31-2003 02:27:59
from your description could be the splines in the torque converter turbine were stripprd.
david
RexB
07-30-2003 21:11:07
Need more partikulars & symptoms:
What year, ie: Hydraulic or dry clutches?
Is the xmsn fluid ok?
Does it jerk, or Nothing, when you put it in gear?
a crawler, is the brake on or brake bands frozen?
If you have a 'reverser', is it in gear and has fluid?
Checked hyd filters for blockage/water?
