Bendix spray tips
Ty
07-30-2003 19:23:02
I have 2 82522-7 tips one has 1 hole open, other has 4 holes open. Everything that I tried didn't do jack squat. What can I do to open the holes. New tips unavalible from deere. Otherwise where can I get them or have some one open them up again. It would be nice if I could do it myself.
Clooney
07-31-2003 03:27:28
 Re: Bendix spray tips in reply to Ty, 07-30-2003 19:23:02
TY, I don't have a tip hole size chart handy. Might not have those hole sizes even if I can find the chart.
~The first thing to do is find the tip hole size, then see if you can match that size [or slightly smaller] to a small wire drill bit size. If you can, a proper sized wire drill bit & pin drill vise will open those holes up. A broach is better though as it won�t alter the spray pattern. Either that or send them out to a diesel injection shop. ~Deere had a part number & used to carry the proper sized broach for some of the old Deere tips so you might try Deere�
~A few years ago I soaked a set of tips in a jar of lacquer thinner for about a whole winter & then blew them out with an air nozzle & managed to get them clear without invasive surgery.
Ty
08-02-2003 10:01:26
 Re: Re: Bendix spray tips in reply to Clooney , 07-31-2003 03:27:28
The paint thinner is unreal. Soaked for a hour have 9 out 0f 10 holes open. Letting it soak longer for the last hole. Putting it all back together now. By the end of the month should be running for the first time in 15 years. God I love how that std. looks!
F-I-T
07-31-2003 06:13:57
Clooney:
In my '70' book it says there are 5 holes, .010" in diameter, if that helps.
Frank
MIKE HANLEY
07-31-2003 00:12:04
Our JD dealer (Westby WI) sends out all it's injector and rack work on 720/730's to a place in Sun Praire WI (Madison Wi) called Sun Praire Diesel. They have all the parts needed. The last work I had done on a 730, the dealer called them and I hand carried it down there and two days later they UPS'ed the stuff back to the dealer all tested and ajusted and ready to install. Recall all those posts several pages back on that 435 with the 3 cylinder GM engine and I said that there was a place that stocked the 435's engine? This was the place. When I saw the engines, they were right at I-90 and state hi-way 51. They have since moved right into Sun Praire proper. Another guy to give a call to is 2-Cylinder Diesel shop in Conway MO 417-589-3834.
