G vs A Pistons
GaryW
07-30-2003 18:10:14
I was reading some posts on this board that indicated that all G's come from the factory with all fuel pistons whereas the late A's came out with gas pistons thus explaining why a late G and A have virtually the same horsepower even though the G has a larger bore and stroke. What is the major difference in the all fuel piston vs the gas piston. How would you convert the all fuel G to gasoline besides changing the pistons? What kind of horsepower would a G produce with aluminum pistons? I have a late styled A and I love the way it pulls and sounds. I am condidering purchasing a G for my next toy. Any input is appreciated.
JDGnut
07-31-2003 20:27:28
 Re: G vs A Pistons in reply to GaryW, 07-30-2003 18:10:14
Gary... on the G's there is only about 1/4-3/8 in difference in height of the pistons... not really enough to make much of a HP difference.. the M&W style pistons are about 1 1/4 in taller... with the stock head on a styled G.. the M&W piston increase the compression ratio to a whoping 6.5 to 1.. A good increase in HP.. but tons of room to go... I have a pic of all the pistons lined up.. I'll see if I can find it and posted it... JDGnut
(Bryan)
GaryW... you from north of Dallas????
GaryW
08-01-2003 05:54:20
 Re: Re: G vs A Pistons in reply to JDGnut, 07-31-2003 20:27:28
Bryan,
Thanks for the info. Yes, I'm from Gainesville TX. There is an antique farm machinery show near Lindsay, Texas (just west of here on US 82) on Aug 30 and 31st. Lots of two cylinder tractors plus an old steam tractor and threshing machines. If you're in the area check it out. Thanks again.
Gary
buickanddeere
07-31-2003 17:07:41
The G was made to be abused for years lugging it's guts out on heavy loads long after other same HP tractors wore out. Bounding over rough ground that would break other lighter built tractors. And all this while buring the cheapest slop that would pour and burn coming straight from some oil/gas wells. Or the cheap left overs at the refinery. Hence the large displacemnt per HP caused small heated high velocity ports and compression low enough not to knock.
D.W.
07-31-2003 11:47:19
I haven't had mine on a dyno as it has the (fat) pto shaft.....no tag, I think 1947, but
the 55 hp range sounds right to me. I went .125
oversize with pistons from Hinrichs Repair and am confident that I turn 50 + hp. D.W.
Jack
07-31-2003 09:04:59
The difference in pistons is the distance from the wrist pin to the top of the pistons.The high compression pistons fill more of the cumbustion chamber raising compression.The G you might buy may already have these in it.Get a compression checker and see if it has around 100 psi or more and if it does,your in the chips.My 53 G had them already and all I had to do is freshen it up a little and cut the head down.55 hp is relativly easy to achieve w/o stroking.That 2.5 mph first gear will get you down the track fairly quick but you need good power in the 7000lb classes.
GaryW
07-31-2003 10:58:38
 Re: Re: G vs A Pistons in reply to Jack, 07-31-2003 09:04:59
Jack,
That makes sense. I was always puzzled why the A and G were rated about the same when the G has the larger bore, stroke and cu in. Thanks for the info. Is 53 the last yr the G was produced?
Jack
07-31-2003 14:07:00
 Re: Re: Re: G vs A Pistons in reply to GaryW, 07-31-2003 10:58:38
Yes,they only made them a half a year in 53 before changing to the 70 series.Email if you want and we'll talk G's.I have pulled and worked on several of them and owned two 52's and a 53.Later Gary,Jack(TN).
John Webster
11-10-2004 15:46:20
 Re: Re: Re: Re: G vs A Pistons in reply to Jack, 07-31-2003 14:07:00
Hi Jack,
I live in N.E. Alabama, have a 53 GW and desperately need someone with your experience. THe tractor is running fine, but I would eventually like to send it off to be rebuilt.
(I hear a high tone ping once every few seconds that concerns me. I do not want to let snything go that may do damage.)
I would really appreciate advice on where to send it. I plan to keep the tractor and will have it gone through at some point problem now or not.
Best regards,
John
256-657-6534
JD70Jim
07-30-2003 18:41:11
Figure that a 70gas is nearly what a gas G would be like, except that a gas G would have the 413 cid engine. My Guess is something like 55-60 hp.
