620 clutch pulley paradox...
dajo
07-30-2003 13:27:05
my dad and I have a 620 which moved until just last winter. a friend tried to pull a car out of a ditch. the 620 started to pull it out and then just stopped pulling. ever since the tractor acts like it wants to start but it won't get out of its own way. she did drive off the trailer but started to fade quickly.
I checked the clutch disks and surfaces. I replaced all (the back one hadn't been changed in quite some time). adjustment doesn't help a bit. too tight and the pulley spins once you engage it. if you disengage it, it continues to spin. too loose, and nothing happens.
she's been worked hard in her life and the former owner didn't believe in PM. I fear the operating sleeve/pulley assembly is the culprit. she 'snaps' (not as high-pitched as a colleague's 60)in and when you adjust it statically it seems fine. start her up and she runs, just not like a deere.
no one in the tractor club has seen one this bad off. it's got to be something simple, but I'm not familiar with it enough to tell.
Hoby
07-31-2003 13:55:10
 Re: 620 clutch pulley paradox... in reply to dajo, 07-30-2003 13:27:05
Check and see if the clutch plates with the three holes are on the right three pins. Put a clutch in my 720D last winter and put it together on the wrong pins. To much down time plus very short memory. Acted alot like your discribing.
Clooney
07-31-2003 03:09:18
dajo, if the clutch pulley is turning you know the clutch isn't the problem. Something has let go in either the 1st reduction gears or trans/diff. There isn't really anything in those parts that will slip so maybe gravity rolled it off the trailer.
~I would start by pulling the little bearing cap off the 1st reduction cover [the one over the input shaft bearing], then putting it in gear & seeing if the input shaft is spinning. That will tell you if the problem is in the 1st reduction gears or trans/diff area. If the input shaft is spinning you will probably have to pull the trans top cover & take a look.
dajo
07-31-2003 08:56:00
 Re: Re: 620 clutch pulley paradox... in reply to Clooney , 07-31-2003 03:09:18
clooney,
I was going to clarify yesterday but thought I'd wait to research the archives. there's alot on 60 series and this is what I checked up on. take a deep breath, here goes...
as far as the pulley is concerned, if I adjust it just to snap (soft snap) in the pulley will just sit there idly when I engage (tractor in gear). when I adjust it up really close (sharper 'soft' snap) the pulley will start up just about with the tractor (I have it out of gear for this).
when adjusting (with clutch engaged), I've tightened up the adjusting bolts one by one until the clutch pulley won't turn - then I've backed off 1/2 turn and moved to the next. I thought by tightening all the way up this was locking clutch to drive disk - when I disengage the pulley will free spin - however, when the tractor runs the pulley spins, period. brake will not stop it. I did notice when pulled way back the pulley seemed to spin faster (I saw archived info on this- I just don't understand why the pulley moves back to the drive disk).
I can back off the adjusting nuts (still 'snaps' in) but then the pulley will just sit idly. note: when in gear (tractor off) the pulley will move the tractor - this says the pulley gear - trans side is ok to me.
more details - one operating bolt is significantly further threaded than the other two after adjustment. first question is this: does this indicate operating pin problems with the sleeve?
clutch dogs have been replaced (two were well worn) as has one operating bolt (bent). no change in performance. toggles didn't appear very worn nor did pivot pins, though I didn't have specs to compare. I did not check the holes in the operating sleeve.
as I stated, she did drive off the trailer, but something felt wrong. she pulled up and backed up a few times, but she felt like she was fading.
also, there was a time when she'd rattle some when engaging. had to pull back all the way on brake to stop the noise. this hasn't occurred in any recent trials.
I know this is alot at one shot, but I'm over my head. I have learned quite alot about the parts that make up the clutch assembly. I am clueless as to the 'over center' term you used in earlier posts concerning toggles. I still have alot to learn, evidently.
Clooney
07-31-2003 10:04:30
 Re: Re: Re: 620 clutch pulley paradox... in reply to dajo, 07-31-2003 08:56:00
dajo, I'm a little pressed for time right now but to get you started lets address a few of your concerns�. You ask....
~"as far as the pulley is concerned, if I adjust it just to snap (soft snap) in the pulley will just sit there idly when I engage (tractor in gear). when I adjust it up really close (sharper 'soft' snap) the pulley will start up just about with the tractor (I have it out of gear for this)"..... .To adjust the clutch, engage the clutch then back all 3 nuts off until they spin free, then tighten them all until they ALL have the same amount of turning pressure [use a 1/4 drive ratchet [or very short wrench] to tighten the nuts as that is hard to over-tighten using that. From there ALWAYS tighten or loosen the nuts one flat at time & always do the same for ALL 3. Then adjust the clutch using the [keep the nuts even technique] until you get a good clean snap [both in & out].
~"when adjusting (with clutch engaged), I've tightened up the adjusting bolts one by one until the clutch pulley won't turn - then I've backed off 1/2 turn and moved to the next. I thought by tightening all the way up this was locking clutch to drive disk - when I disengage the pulley will free spin - however, when the tractor runs the pulley spins, period. brake will not stop it. I did notice when pulled way back the pulley seemed to spin faster (I saw archived info on this- I just don't understand why the pulley moves back to the drive disk)"..... .DON'T adjust it by pulley turning feel, adjust it by hand lever snap feel.
~" more details - one operating bolt is significantly further threaded than the other two after adjustment. first question is this: does this indicate operating pin problems with the sleeve?"...�.It could mean you have a problem, or you might not have it adjusted evenly, or the bolt is just different.
~"when adjusting (with clutch engaged), I've tightened up the adjusting bolts one by one until the clutch pulley won't turn - then I've backed off 1/2 turn and moved to the next. I thought by tightening all the way up this was locking clutch to drive disk - when I disengage the pulley will free spin - however, when the tractor runs the pulley spins, period. brake will not stop it. I did notice when pulled way back the pulley seemed to spin faster (I saw archived info on this- I just don't understand why the pulley moves back to the drive disk)"...�..Usually when the pulley brake won't stop the pulley that means the pulley brake is adjusted way too loose & the pulley pulls in too far & RE-APPLYS the inner clutch disk so the harder you pull the lever the tighter that inner disk holds & the pulley brake CAN'T stop the pulley, as a matter of fact the clutch grabs harder. If you have a late 620 there are some inner clutch fork stops that need adjusting so if you have a late 620 let me know?
~I know I didn't answer all your questions so read the above & post back with more specific questions. If we go in to too much detail in one long post it will get very complicated & confusing, so lets weed it down to the parts you need to understand...Questions please...
dajo
08-01-2003 08:43:08
 Re: Re: Re: Re: 620 clutch pulley paradox... in reply to Clooney , 07-31-2003 10:04:30
clooney,
I readjusted the clutch last eve. since you have to push the adjusting disk on slightly to thread the castellated nuts, I started with them about half off to hand-thread. adjusted up somewhere about 2-1/2 to 3 turns to get a good snap out. snap in is not sharp like the snap out. to make it its sharpest, adjustment must be real tight.
on start up the (out of gear) clutch engagement does spin the pulley and the brake is adjusted right now and it stops the pulley. however, the tractor won't move still. it acts like it wants to, but it doesn't go anywhere in any forward or reverse gear.
I don't believe it's the adjustment. I think it's something in the sleeve or the sleeve pins I've heard of. I'm not sure of the toggles as they did not appear worn unusally. I suspect I need to take the pulley off to inspect the holes in the sleeve where the toggles insert to check wear.
I need to understand the design of the clutch better to troubleshoot operating sleeve problems. all the other components have been replaced.
also, the sharp 'snap' I've observed on a colleagues 60 and another's H are vastly different than the 'thud' snap I feel in my 620. I can only attribute it to wear. my ignorance prevents me from speculating its source.
thanks for your help. I inch closer to a solution every day.
