JD 4440 hydraulics
Jimks
07-30-2003 10:16:04
I'm working on a 4440, and the hydraulics (including steering)barely work. I'm told that somebody changed the hydraulic filter and there was a spring in it that shouldn't have been there. Any idea what springs are upstream of the filter, and what valves I should check to see where it came from? I'm thinking there should be maybe a transmission pressure regulator valve that'd be upstream... any other ideas?
davidval
07-31-2003 02:39:23
 Re: JD 4440 hydraulics in reply to Jimks, 07-30-2003 10:16:04
if it is quad-range and you have problems with the transmission pump circuit (which is the filter circuit), chances are the tractor will not move.
david
