Approximate Weight of Cyl Block and Cyl Head
Frank, Tx
07-30-2003 07:26:38
I am in the process of taking my 52 B apart. I was able to handle the head by myself and was curious if the cylinder block is much heavier (no pistons, just bare caasting).
ChuckW
07-30-2003 09:51:53
 Re: Approximate Weight of Cyl Block and Cyl Head in reply to Frank, Tx, 07-30-2003 07:26:38
the head is not much of a problem to remove, you probably also need to remove your tool box. If the manifold is still on is a little tricky. The block will also come out but it has to be turned...I can't exactly explain this but it noted in the manuals, one thing I do know for sure is to be careful with you fingers along the frame and not get block wedged up against them. Safety first.
Leeker
07-30-2003 07:40:46
I handled the one off my 50 by myself. But then again I'm 6'3 and 250 lb, and I wrestle 1300 lb steers for kicks on a friday night. I would use some kind of support. Easier on body and less likely to break something. Make sure you clean around the studs first. Also soak the studs in WD-40 or PB Blaster before you try and tug on it.
