Good Morning B Guy, Before I get too deep into any Mag problem, Id prefer you check the plugs and be sure they are clean and not partially fouled, cuz one way to make a partly fouled plug fire is to pull its wire away from a terminal or create an extra added artificial gap in the plug wire circuit (maybe 1/8 to 1/4 inch), and then an otherwise bad plug can go ahead and fire. You might swap plugs and wires side to side to see if you isolate a bad wire or plug or just try a fresh set of Autolite 388 plugs and see what happens first and maybe a different set of wires to insure they are not the problem. At idle on the single barrell carbs, its common for the left cylinder to fire stronger than the right anyway you know. Also, you need to be runnign wire core and NOT carbon ciore auto suppresor type plug wires. If one side still produces a better spark than the other (with good wires and plugs), the same set of points and coil and condensor produces BOTH sparks (could be a difference in the points gap if rotor or rotor bushings are worn, try a slight gap increase to maybe 0.017), also check the gap on BOTH high cam lobes, if the rotor bushings are worn and the rotor wobbles, that can make an RPM spark difference which a wider gap may help temporarily. If the rotor and bushings and cam lobes check out, its time to look at the caps and rotor and the lil spring & assembly where the outer cap mounts to the inner, and look for cracks or residue or carbon traces in the caps and/or terminals or for carbon build ups or cracks by them etc. etc. Of course, the points need to be clean and NOT gray oxide coated (if so clean/polish them) and need replaced if they are burned or pitted or carboned up bad, and make sure the points spring or wires to the points are not shorted or frayed. Duane Larson is very knowledgeable and has good specs and detailed info on those C mags also, but check the plugs and wires and cap and its mount (esp spring and rotor assembly) and the rotor tips and see if that cures the problem. Good luck n God Bless John T Nordhoff in Indiana
