830 JOHN DEERE
STEVE LANGFORD
07-29-2003 23:32:52
HYDRAULICS SQUEALING LIKE A PIG HUNG UNDER A GATE.EVIDENCE OF AIR IN LINES- FOAMING IN RESEVOIR. CAN'T FIND ANY EXTERNAL LEAKS. ANYBODY GOT AN IDEA? THANKS
JW
07-30-2003 20:43:54
 Re: 830 JOHN DEERE in reply to STEVE LANGFORD, 07-29-2003 23:32:52
After fluching the air out of the lines, you might look at (if you have a 3 pt) the load adjustment screw. My 4010 made that kind of noise after warming up good. The 3pt load adjustment screw was sheared off and was preventing one of the 3pt valves from recieving enough pressure to operate. I took mine to a Deere service center and after several attempts they understood that the squeel that I was hearing was not my imagination. When yours goes to squeeling take notes on what operations affect the squeel such as brakes, 3pt lift movement, 3pt up all the way, 3pt with implement down on the ground (what mine was doing), positive weight on the 3pt lift arms (what stopped mine from squeeling), power steering operating and anything else that the hydrolic system operates.
