1032 Snow Blower
Steinway
01-16-2004 07:28:59
Having 2 problems:
1. Having trouble starting below 20 degrees. Even with electric start the motor won't kick over, any suggestions?
2. Seems the motor is leaking oil, find a puddle under the unit after use, and drips on the driveway during use. Any suggestions?
Bob
01-16-2004 07:45:33
 Re: 1032 Snow Blower in reply to Steinway, 01-16-2004 07:28:59
1. Is the starter actually turning the engine at a good rate of speed? Your choice of words is confusing. If it is turning over well, it sounds like a basic tune-up is needed... Replace the spark plug, and if there is any question of the quality of the gasoline, drain carburetor and gas tank, and replace with fresh gas.
2. As to the oil leak, your gonna have to get down and dirty, face first up to the thing, and have a look. If you can't tell where the oil is coming from, when you're there next to it, it becomes an order of magnitude tougher to diagnose by remote control! Possibilities are... crankshaft oil seals, or bad gasket on crankcase, or valve cover gasket. (Assuming the oil level in it is correct.)
Steinway
02-04-2004 06:45:53
 Re: Re: 1032 Snow Blower in reply to Bob, 01-16-2004 07:45:33
Bob: Thanks for the responses. With respect to the starter, replaced it last year. I use the electric starter so the engine is turning at a good speed. Did get it started the other day at about 26 Degrees F. Question, would a shot of Starting Fluid help at low temps?
More info on the oil problem. Once the machine started it ran well for about 20 minutes then the wheels would not drive the unit. Seems like oil may have been leaking onto the clutch or drive assembly and not letting any torque transfer? Your thoughts please.
fishtale
01-17-2004 16:22:53
In our neck of the woods, we have found that the Tecumseh carbs are trash after a few years usage. You might try removing it and soaking in real strong carb cleaner overnite, blow it out and reinstall. I own two with the same starting problems.Otherwise same time and aggrevation,buy a new carb.
paul
02-04-2004 08:12:58
 Re: Re: Re: 1032 Snow Blower in reply to fishtale, 01-17-2004 16:22:53
I am looking for some pictures of the wireing around the carb on the 1032. The guy before me unhooked it and I would like to hook it back up. It is the wires that run the auger from the handle levers. I think it is a 1986 model.
fishtale
02-05-2004 06:04:21
 Re: Re: Re: Re: 1032 Snow Blower in reply to paul, 02-04-2004 08:12:58
I am not sure what wires you are referring to. My 1032 has mechanical rods operating the auger and trans. Please clarify further these wires so I can help you. I own 2 1032's and am pretty familiar with them.
Paul
02-05-2004 06:09:53
 Re: Re: Re: Re: Re: 1032 Snow Blower in reply to fishtale, 02-05-2004 06:04:21
There is a rod from the handle for auger, but on mine there is a picture that show the two top black lever will engage the auger when pressed. They have some wires that run from them to the area around the carb. The wires around the carb are unhooked and the thing runs great so I don't think they are for the motor. I was thinking it might be a saftey thing when you take both hands off of the handles the auger will stop turning. I may be wrong but I would like to know what the unhooked wires do. You can email me at [email protected] Thanks much for your help.
