Phillip, well an entire treatise could be written on your question, but I will just try and give you an overview which Im sure others will add their expertise to, so maybe after you read em all you will understand it or be thoroughlly more cornfused lol. 1) Yes, the starter and generator are both 2 wire 24 volt units, and their steel case frames are isolated and insulated from the electrical system and any of its wires. On most 12 volt starters, their steel frame makes up one of the connections (frame ground) with the other connection being the heavy insulated mountign stud where the cable attaches. On 24 volt starters and generators, there are 2 connections insulated from the case and they attach to the 24 volt source, while NEITHER is electrically connected to the steel frame anywhere. 2) To get 24 volts, you can wire up in series either four 6 volt batterys + - + - + - + - (ground tie point in center) or two 12 volters + - + - (again tie point ground in center) and the outermost points for 24 volts would be the + terminal on one battery and the - on the other opposite side batterys outermost terminal. 3) At the center tie point of the batterys (12 volts on either side) that point is tied (wired) to the tractors steel frame. Therefore, from the outermost untied battery terminals on each outer end, there would be 12 volts from it to ground. One of the batterys outermost untied terminal would be a Negative post, so that battery (or batterys if four 6 volters are used) is wired with its Positive post to frame ground and is Positive grounded. The other batterys untied outermost post would have to be a Positive post, so that battery (or batterys) is Negative grounded 12 volts between it and the tie ground center. You then have a source of 12 volts at negative ground and another 12 volt source positive grounded. The 24 is across the whole series of batterys, being the outermost untied ends of the opposite side batterys. 4) Now as you know, the lights and other loads on the tractor run on 12 volts and NOT 24 plus many such loads are intended to be attached to the tractors steel frame which serves as one of the current conductors. They have but 1 wire out of them, while their steel frame is intended to be bonded to the tractors steel to get a return path for the current. 5) Now its best for the batterys if all are loaded approximately equal, so how it works is there are 2 circuits (from those 2 outermost untied batterys posts described above) going to the main switch, an "A" circuit which is 12 volts positive to ground, and another "B" circuit which is 12 volts negative to ground. Then some of the 12 volt loads are fed from that switch via the A circuit, and others fed 12 volts via the B circuit. The switch can supply 12 volts to different loads, its just that one is off one battery bank and at positve ground and the other off the other bank at negative ground. 6) The generator is a 2 wire 24 volt unit and its output goes to the 2 outermost untied battery posts on the opposite sides. It charges all the batterys together in series. MAKE ANY SENSE AT ALL????? Thats why the 24 volt starters have 2 big terminals and 2 cables going to them (attached to the outermost untied battery posts on the opposite sides), not just one with the frame making up the other connection. As Forrst Gump said "Thats all I have to say about that" for now at least. Post back any more questions. Good Luck n God Bless John T Nordhoff in Indiana
