Help needed - Sleeving D block
jon
07-29-2003 19:27:56
Can anyone who has the crankcase cover off a "D" tractor measure the amount [length] of piston skirt that sticks out into the crankcase area at bottom-dead-centre. I am ready to sleeve my replacement block but the machine shop says that they have to leave a 1/16"th to 1/8th" inch step at the bottom of the bore to secure the sleeve in the block. By my measurements, that would leave the oil ring stopping just at the edge of the sleeve end. Mine is completely disassembled or I'd measure my own.
Thanks in advance!
Jon
Johnbob
07-30-2003 17:41:14
 Re: Help needed - Sleeving D block in reply to jon, 07-29-2003 19:27:56
The oil ring goes to the end of cylinder wall.I had to put sleeve out of the block 1/2 inch and weld at the edge of block.Been there done that.
Donny-B
07-29-2003 20:47:05
Just curious, what is the machine shop charging you to sleeve a D block? In my area (Harrisburg, PA.) the going rate is $1200. That includes re-bore to your piston size.
jon
08-04-2003 19:17:57
 Re: Re: Help needed - Sleeving D block in reply to Donny-B, 07-29-2003 20:47:05
Donny-B,
I am in Canada. The price seems to be about the same in Canadian dollars as you pay in US dollars, so about 800 USD. The sleeves come for the United States - no local suppliers. Suggest you use a local shop. Shipping, duty and customs clearance will about equal the cost delta.
Earl S.
07-29-2003 19:40:46
If your machinist thinks he needs to do that have him cut a step on the OD. of the sleeve then it won't interfere with the oil ring. The old Versnick sleeve Co use to make all their sleeves with a step on the OD. Earl In Illinois
