Hi- lo transmission
Diesel Rider
07-29-2003 18:53:38
I'm looking at a 2640 with a hi-lo tranny also known as the rabbit and turtle. This feature is in addition to the 8 forward and 4 reverse gears. I don't know a thing about them other than the name. Can anyone tell me what to look for on them? It sounds like IH's tork amplifier and I have heard they can be alot of trouble IH that is. is JD's the same or are they reliable? Thanks.
Dieselrider
07-30-2003 15:43:14
 Re: Hi- lo transmission in reply to Diesel Rider, 07-29-2003 18:53:38
Thanks guys for all the input. These units sound really good. I can't wait to talk to the guy that has this 2640 for sale.
davidval
07-30-2003 11:07:14
the hi-lo shift unit is a 2 speed planetary unit between the clutch and the transmission input shaft. there is a (if i remember well) about 27% reduction in low and direct drive in high. it allows you to shift from high to low under load on the go without using the clutch, and back.
when you need more pulling power for a short period of time (like ploughing over a compacted lane in the field) you shift to low, when you pass the rough spot, you go back to high. the speed difference is almost one gear but not exactly so.it's not 1/2 a gear.
using the speed table you can choose the right speed for accurate pto jobs (like spraying) so you actually get 16 speeds in this respect.
to take care of the unit, always make sure there is enough oil in the transmission, never try to tow start the tractor, never use the unit to get engine braking at high speed (especially with a trailer) and never 'coast' the tractor with the clutch depressed.
this unit went through lot of improvements during the years and in the 40 series tractors it is quite reliable.
david
Kydirtfarmer
07-30-2003 03:41:01
The Hi-Lo is the greatest thing since sliced bread. (Most of the time) My brother in law has a 2440 with it. I have a 2440 with out. We both have about 1800 hours on the tractors. His has been NO MORE TROUBLE than mine. The biggest thing to watch for is, 1. Don't EVER try to pull start the tractor. The transmission will explode! 2. If the tractor ever needs to be split, it will add about $3000 to the bill. This would include splitting it for a clutch. The 2640 is a great tractor. Just take proper care, and you'll not have a minutes trouble out of the Hi-Lo. Both the 2440, and the 2640 are proned to what is known as electroulisis. It is caused by dirt particles in the cooling system. They literally sandblast holes in the cylinder sleeves. Look for signs of water in the oil/oil in the water, and steam coming out of the engine breather tube. If the original owner took precautions with the anti-freeze, and kept it clean, there won't be any trouble. Hope this answers your questions. Now go get that tractor! Bill
Mike
07-30-2003 05:56:53
 Re: Re: Hi- lo transmission in reply to Kydirtfarmer, 07-30-2003 03:41:01
A strong I second that on not pull starting them. I had to rebuild the hi lo unit on a 2840 for a guy that thought he did not have the time or money to buy a starter and ended up spending thousands.
Pete/ME
07-30-2003 03:34:00
Got it on my 2240, never had a problem, hardly ever use it, the difference is minimal, only when I need to go real slow near a building.
Dieselrider
07-30-2003 03:37:47
 Re: Re: Hi- lo transmission in reply to Pete/ME, 07-30-2003 03:34:00
Pete, So you can run it like a straight tranny without the hi-lo? Do you just leave it in one position or the other or in the middle? Thanks.
Pete/ME
08-01-2003 03:42:47
 Re: Re: Re: Hi- lo transmission in reply to Dieselrider, 07-30-2003 03:37:47
There's no "middle". I just leave it in high. When the tractor is moving and I shift the hi-lo, it just slows down a tad, the rpm doesn't sound like it changes.
