Clutch pulley bearing and dogs
Frank in WV
07-29-2003 09:27:30
I have taken the clutch pulley apart on my 48 A. What grease should I use to repack the bearing with? How can one tell if the dogs on the toggles are worn? Should I spray some sort of cleaner on the dogs to make them work better? They seem to move pretty free now but wondered if carb cleaner sprayed on them wouldn't hurt. All suggestions appreciated.
Clooney
07-29-2003 11:46:50
 Re: Clutch pulley bearing and dogs in reply to Frank in WV, 07-29-2003 09:27:30
Frank in WV, I use the same type grease as Frank [F-I-T].. A good quality hi-temp wheel bearing grease. Buy good grease as the cheap stuff separates & will bleed into other places. ~On the dogs [pivots],, as Frank said [I think he mis-typed] the pivot pin holes do wear in both the pivots & pulley ears. When those pins & pin holes wear they move the over-center point so the toggles will no longer go over center or stay there even if they do go manage to go over center. The toggle pockets in the pivots also wear deeper & at an angle [again causing an over center problem for the toggles to go over center]� Look at the other end [the pockets in the operating sleeve] if those holes wear deeper or at an angle the clutch won�t snap over center properly either [common problem].
~On the toggles..they usually don�t wear too bad & are quite expensive for what you get. About all you can do is measure them against a new one for length. [don�t ask me for lengths as I started a chart long ago but lost it some where in the shop]. I have found that if the pivots & pivot pins & pockets are good that most toggles will still work good. ~One other thing that causes poor clutch feel & operation is a worn anti-rotational pin, or pin hole in the operating sleeve. If that sleeve is allowed to rotate, some of the toggle(s) over-center action is lost to side motion & they won�t go over center properly. Usually if that pin or pin hole is worn the clutch adjustment or feel keeps changing & the clutch usually feels different with the engine running & turned off..
~Un fortunately the specs on those pivots, toggles & the operating sleeve are almost non-existent so a lot of the wear has to be evaluated by eye. It�s kind of a subjective thing. Once you have done a few you will know what to look for. If you know some old gray bearded Deere guy that has worked on those old 2-cylinder tractors for years he is your best bet to evaluate those parts. The problem is, by the time a person know what they are looking for they can�t see anymore without a 100, 000 candle power light & magnifying glass.
~Almost forgot...also look at the adjusting bolts for step wear on their sides & wear at the pivot contact area. If those bolts have a step wear problem they could catch in the pulley holes under load.
F-I-T
07-29-2003 12:33:37
 Re: Re: Clutch pulley bearing and dogs in reply to Clooney , 07-29-2003 11:46:50
I always confuse the dogs with the toggles. That's why I usually say "dogs/toggles"...
Sometimes you get caught !
I also like to, at a minimum, grind or smooth any rough spots on the bolts. On our '48 'A' they had a ridge formed that would catch on the edge of the hole they went through in the pulley. We removed that ridge and they moved just fine. The old timer at JD also said to watch that pin hole fit in the operating sleeve. Ours was pretty worn, and I think at the time my dad cringed but spent the $60 bucks or so that it cost.
You won't find new ones for that these days.
Frank
F-I-T
07-29-2003 10:06:06
Frank:
I've always used Hi-Temp wheel bearing grease on the bearing, and used a dab of the same on the dog/toggle joint (cup). Any light fluid/cleaner like carb cleaner will just dissipate quickly under the heat of normal operation.
The toggles will usually wear at their pivot pin, and for that you can either weld and re-drill the hole, or drill out to next size that removes the wear.
Frank-in-Tallahassee
70D // 855
