A little more info on the voltage regulator
F-I-T
07-29-2003 08:23:10
I filed the points and that did not help. Then I saw the four wire-wrapped posts in the regulator, and thought that might be a source of a possible intermittent connection, so I floated a small amount of rosin core solder on those. THen it started charging.
HOWEVER...as it was running with the voltmeter connected and lights on, I pushed in on the FLD relay to see that the points would break, and lights went out. Release the relay, they come on, open the relay they go out. Shut-off engine, switched on lights, no indication on ammeter, and lights don't work with switch off !
I think the shunt must have let go in the ammeter ?
Is this a realistic evaluation?
Voltage with lights on is about 6.9, lights off 7.42v. Not sure where it should be, but that sounded pretty fair.
Need to know if I should order a new ammeter (the old one was original and has been through the wars).
Thanks to all.
Frank-in-Tallahassee
70D // 855
John T
07-29-2003 09:26:42
 Re: A little more info on the voltage regulator in reply to F-I-T, 07-29-2003 08:23:10
Hi Frank, first of all, I tried all mornign to e mail you a diagam of a VR via the Johnnypopper Web Site system per your last nights request, but it just wont go through????? and wheres that VR pic I saw the other day??? here below or over on Johnnypopper?? cuz is that a 4 wire VR with the 4th extra LOAD terminal that feeds lights and loads or a 3 wire with the lights fed off the ammeters load side???? Send me an e mail ([email protected]) via your regualr e mail and NOT via the Johnnypopper Board maybe????
Anyway, the ammeter should ohmmeter test like a near short circuit, with battery voltage therefore showing present on BOTH sides. If its open, then a test lamp would indicate battery voltage ONLY on its battery supply side and nothign over on its load (non battery) terminal. A simpe continuity and/or voltage test should answer your ammeter question. Remember, dont have any voltage on it if you use an ohm meter.
From your description, I wonder if the light switch loads are fed off the ammeters load side (like on 3 wire VR's) or down off the LOAD terminal on a 4 wire VR???? Whats on the load side of your ammeter???? If ONLY the wire to the BAT terminal on the VR is there, then I assume the feed wire to the lights is off a LOAD terminal on a 4 wire VR right????? ?? If the lights are fed off the ammeters load side, then if theres power on its battery supply side but none on the load side, it indeed may be bad and open.
See what VR you have, insure the ammeters a closed circuit with voltage on BOTH sides, and where the lights are fed from and we can proceed.
Were gettign there.
Your friend, John T
Clooney
07-29-2003 09:33:57
 Re: Re: A little more info on the voltage regulato in reply to John T, 07-29-2003 09:26:42
John, the pony start 2-cylinder diesels don't use a load terminal on the regulator. There is no ignition load with a diesel.
John T
07-29-2003 09:47:04
 Re: Re: Re: A little more info on the voltage regu in reply to Clooney , 07-29-2003 09:33:57
Thanks Clooney Man, I havent had a chance to look at his pic again which would have answerd that already. He could still have light loads though even without any ignition, and I didnt know where they were fed from, but if its just a 3 wire VR, then they should be off the ammeters load side. Once he checks his ammeter though, we will know more whats happening huh.
Take care up North of me my friend.
John T
F-I-T
07-29-2003 10:33:22
 Re: Re: Re: Re: A little more info on the voltage in reply to John T, 07-29-2003 09:47:04
Yup, it's a three wire VR.
I ran a quick jumper wire from the BAT wire on the VR to the main starter cable (which feeds through the small wire to the dash switch/ammeter), and the lights work fine, so either I have an open in the ammeter or a loose connection.
Why does it always happen when you have the hood on and all the bolts painted.....
F-I-T
Clooney
07-29-2003 11:07:30
 Re: Re: Re: Re: Re: A little more info on the volt in reply to F-I-T, 07-29-2003 10:33:22
Frank, I usually just pull the oil pressure line & tac cable & pull the IP panel towards the rear. You should be able to get to most of it through the pony door though. Depends on your hand size & eye sight focal length. With me it's not my eyes it's that my arms are getting shorter.
~On those IP bolts a little trick I have found is to use small copper washers under the bolt heads, you can�t see them but they don�t tear the paint up when the bolts are removed like those original washers do�.
F-I-T
07-29-2003 12:26:58
 Re: Re: Re: Re: Re: Re: A little more info on the in reply to Clooney , 07-29-2003 11:07:30
Thanks Clooney. I already habe mine a bit chipped up, but I might try to find some small copper ones. I know years ago, I started using star washers under the panel, held on with a dab of grease so they wouldn't fall off during assembly. It seemed to help with the ground path there, though I'm not sure if that is true or not. Back then we were doing anything to either get the pony running and keep it running or any thing to get it charging and keep it charging.
I'll probable pull the panel. My hands are too fat and my glasses are too thick !
BTW, I orderd a new VR when I ordered the ammeter.
I might even take the hood back off, because there was a bit where I wanted to buff out some more and couldn't get to it very well with the hood installed. It's not an expo tractor, but I try to keep the ding ups to a minimum.
Got a new (city feller) neighbor who asked me when John Deere started making that model. Said he hadn't seen any at the dealer....yet.
Frank
Clooney
07-29-2003 09:08:50
Frank, that would be my guess, OR, there is a loose connection at one of the ammeter posts... Just install a temporary jumper wire between the ammeter posts then use your voltmeter to monitor the charging voltage. If the jumper gets your lights working correctly that means either a bad connection or the ammeter went bad....
