Bosch Alternator
Navigater
07-28-2003 22:23:59
Does anyone know how eliminate this bosch alternator by replacing with a delco? JD 1530 has a bosch 28amp, that JD wants 254.00 for a rebuilt unit, & aftermarket types are not much cheaper, any info would be great. Thanks, R.W.
JB
07-29-2003 19:22:24
 Re: Bosch Alternator in reply to Navigater, 07-28-2003 22:23:59
One of my brother's IH 495 or 684 had the same alternator. If I remember correctly it had a 3 wire plug. The first problem was the idiot light would come on dim and eventually it came on all the time and then it stopped charging. The problem was that the ground for the rotor was a ground brush that made contact with the end of the rotor shaft. The ground brush had worn away. We fixed it by brazing another piece to it. Eventually it failed again. We went to the local car wrecker and found a single post Delco from a GM wreck for $20.
The only change required was a longer mounting bolt and a longer fan belt. We connected the Battery wire and the wire to the idiot light and tied back the third wire. I have seen the instructions on this web site for doing this on I believe the IH forum. Many IHs from Britian had Bosch or worse Lucas electrical systems.
Jb
