Clooney - Anyone - Hyd. line question
Wayne in Tn.
07-28-2003 10:22:56
Concerning the Dubuque Hyd. suction line, I have always been confused as the the proper order of the (seal) and (ring) on page 55-4 of the parts book: PC 505. shows the order of Keys number 4 and 5. I have taken them apart before and 4 and 5 were reversed from what the picture shows, and this looks like it would be correct, instead of the way it is pictured. What purpose would the ring (key-4) to be installed first, looks like it should be installed between (key 6 & 7) ???? Or would this be correct to do it as the book shows??
Clooney
07-28-2003 11:51:05
 Re: Clooney - Anyone - Hyd. line question in reply to Wayne in Tn., 07-28-2003 10:22:56
Wayne, I don't have PC-505 handy, if you are talking about those thin metal washers I usually install those between the nut & rubber seal. I never looked in the book to actually see how they go but just assumed they would go between the nut & rubber so the nut wouldn't twist the rubber ring when the nut was tightened�. If you think about it [I know that could be dangerous] you really want that rubber ring to seal against the housing bottom & not the nut, sealing against the nut does you no good unless the nut is also sealed to the housing. In reality though it probably makes no difference as that rubber should swell up when tightened & seal between the pipe & sides..
Wayne in Tn.
07-28-2003 13:24:34
 Re: Re: Clooney - Anyone - Hyd. line question in reply to Clooney, 07-28-2003 11:51:05
Clooney, it is hard to explain without seeing the photos. The location is at the top and bottom of the steering pedastile. It is not a nut, it is a flat piece of metal with two 1/4 inch bolts. The seal looks like a piece cut off a heater hose and the other is a metal ring, It seems as if the metal ring should go against the piece of metal, instead of down in the bottom of the line opening. I don't have much luck trying to scan or send pages from the parts book, maybe someone else can.
F-I-T
07-28-2003 13:37:13
 Re: Re: Re: Clooney - Anyone - Hyd. line question in reply to Wayne in Tn., 07-28-2003 13:24:34
third party image
WAyne: Hopefully this will help. Not knowing anything about the installation though, I was wondering if the metal ring is used in the bottom to prevent the rubber "hose" from being forced down into the i.d. of the tube. Let me know if I can help post any other views. Frank
Clooney
07-28-2003 14:25:32
 Re: Re: Re: Re: Clooney - Anyone - Hyd. line quest in reply to F-I-T, 07-28-2003 13:37:13
Wayne, now that Frank posted the picture I know what you are refering to. On those connections the washer does go in first. I believe for the reason Frank pointed out. That washer is for the rubber to seat against so it will compress properly & not squeeze in too far between the pipes.
Wayne in Tn.
07-28-2003 13:47:18
Hey Frank, thanks for posting the view, you may be correct about the metal ring being in the bottom of the line. That is the way it is pictured in the Service Manual also, but there is no text to verify this. Thanks again...
