6-row cultivator for a John Deere B?
CEO WILLOW CREE
07-28-2003 08:35:48
Back before we went to 30 inch rows we use to cultivate with a 4 row front mount on a 1952 John Deere B. Never seemed to have any problems. After spending 2 summers with a rear mounted 6-row cultivator, I have made an executive decision that I am going to create a front mounted 6-row if it kills me, cuz if I don't the neck pains from another season probably will. All the tractors on the farm are larger... aka. 140 hp+ other than the old John Deere B, still have the 4-row cultivator in the shed ironicly.
My question is if I lengthen the bars, and adjust the sweeps I can make 6 rows. The question is will The "B" be able to handle it? We aren't talking about diggin in real deep here, nust deep enough to cut out the volunteer corn!
CEO WILLOW CREEK FARMS
Tye
07-28-2003 17:59:00
 Re: 6-row cultivator for a John Deere B? in reply to CEO WILLOW CREEK FARMS, 07-28-2003 08:35:48
Rule of thumb: The smaller the implement, the more times you get to go around the field- HE HE ;)
ET
07-28-2003 12:10:20
I have a cultivator on my 50 that has been changed to 6 rows from 4 and it works real well. In 30" corn rows you can work the ground between the row real good with 3 shanks. I also find less shanks don't plug as quik if the weeds get big. I have seen a 6 row unit on a B in the past that worked ok. I don't think it would run it any faster than 3rd gear. The bigest concern would not breaking the frame so I would take it easy on rough ground. You have to add a little on the cultvator frame to get the extra rigs on for 6 rows. The best thing is to find another 4 row doner cultivator. You will need the gauge wheels on the outer rigs. I found that by hooking the front truss bars to the bottom of the suport clamps it helps eliminate the twist you get on the longer frame bars. Good luck
John Jenkins
07-28-2003 10:27:15
A 6-row (30�) sweep cutivator is a fair load for a 4020...especially if it is of the 5-sweep variety! I can�t imagine what a B could do with one.
phil
07-28-2003 10:15:52
How about Round-up Ready beans & corn?
CLW
07-28-2003 09:29:50
Dr. Evil is correct. The frame was cracked by 4-row on many B's. The 6-row would be too much weight and as others said, would be a bear to turn around. If you ever put the 4-row back on please post a picture in the tractor photo's. Been a loooong time since I have seen a B with them on. Drove the A and B as a kid with 4-row and that was the only time I liked to drive the B best. CLW
Leeker
07-28-2003 09:22:51
4-row on a B??? I have a 1950 B and couldn't imagine turning it with a 4 row cultivator on it!!! Your trying to do to much with to little!!!! Leeker
Jake
07-28-2003 08:46:03
Depends if you will be able to steer it with all that weight on the front. It's bad enough with my B using a 2-row cultivator.
07-28-2003 08:56:24
 Re: Re: 6-row cultivator for a John Deere B? in reply to Jake, 07-28-2003 08:46:03
Good point... it was hard to turn with the 4-row... maybe I could use a hyraulic steering kit?
Jake - power steering wil
07-28-2003 23:11:22
 Re: Re: Re: 6-row cultivator for a John Deere B? in reply to CEO WILLOW CREEK FARMS, 07-28-2003 08:56:24
I don't recommend a power steering kit on a B. I think you will just tear up the steering gears and you can't get those anymore. I have a JD B too, it's a nice original tractor, the roller bearings had made grooves in the worm shaft races, which locked the steering wheel under even the tiniest load. Looking for used parts took a while because many of the gears I took out of used tractors were chipped or broken. Seems to be a weak link on an other wise OK tractor.
Dr.EVIL
07-28-2003 09:11:38
Guy I used to do fieldwork for during HS & College did exactly what Your thinking of, convert 4-38" cultivator into a 6-30". He mounted it on a 520 and it sure did make that old tractor pound & hammer. I think third was about as fast as He could cultivate. He just used it for soybeans. If Your B has the pressed steel frame I wouldn't even consider it though.
MIKE S.
07-28-2003 18:55:15
 Re: Re: Re: Re: 6-row cultivator for a John Deere in reply to Dr.EVIL, 07-28-2003 09:11:38
LOAD THE WAGON, DON"T WORRY ABOUT THE MULE HE"S TUFF!!!!! !!!
