Clooney! Its my PTO on my D
Daniel N.
07-27-2003 19:20:05
Hey Clooney,
On my 1950 D the pto is leaking. It started when i first used the pto to spread fertilizer. I'm pretty sure its the gasket that needs to be replace, but what i'm not sure about is how the pto comes off. Do i have to disconnect something in the main case under the starter or could i disconnect the quill and pull it off to put the new gasket in??
Bob-Wyo
07-27-2003 19:49:33
 Re: Clooney! Its my PTO on my D in reply to Daniel N., 07-27-2003 19:20:05
Daniel, if it's leaking between the rearend case and pto quill, just remove the 4 bolts and shift rod and it will come straight out the back about 4 feet. Now getting it back in some times is trying, but go in straight and most times you will hit the spline hole up by the transmission even on the first try???? and then to it may take more if it's like the last one I pulled. lol.
Be sure and grease the rear pto bearing to, most I have had apart were dry.
Hope this helps. Glad to hear you are using your D.
Bob
Clooney
07-28-2003 04:03:47
 Re: Re: Clooney! Its my PTO on my D in reply to Bob-Wyo, 07-27-2003 19:49:33
Daniel, I can't add much to what Bob said. ~If the leaking just started you might want to see if you have a lot of water in the trans. Sometimes water in the trans will bring on trans leaks.
~I use a 3' pipe on the splined part of the PTO shaft to hold & guide the front PTO shaft back in as it gets hard to manage using just that housing & short shaft out the rear.
