4430 hydraulics slow down steering drifts
David Owen
01-15-2004 20:43:16
I have a 4430 that the hyrdraulics are slow & the steering drifts to one side when driving . We have changed filters, fluid & even swapped pumps. Any ideas
Jim B
01-16-2004 04:34:26
 Re: 4430 hydraulics slow down steering drifts in reply to David Owen, 01-15-2004 20:43:16
David,have you checked for an internal hyd. leak.You can get it to operating temp. and check to see if one of the hyd. components feels hot.The wandering steering is in steering valve or steering motor has bad o-ring.I think late 4430's have metering pump steering which gives less trouble.Which pump did you change out and have you checked stand-by pressure?Stand-by press. should be 2250 psi.Jim B
David Owen
01-20-2004 04:39:33
 Re: Re: 4430 hydraulics slow down steering drifts in reply to Jim B, 01-16-2004 04:34:26
We swapped the front pump. We will check the standby pressure again. Will be back. Thanks
