830 power steer leak
robert
07-27-2003 19:16:35
Does replacing the packing o ring,and gasket above steering tube -and below quill usually cure bottom case leaking PS on 2 cyl. 830 ?? thanks in advance.If so is it not fairly straight forward??
Gerald R.
07-29-2003 05:21:55
 Re: 830 power steer leak in reply to robert, 07-27-2003 19:16:35
Robert,
The steering tube is an intergral part of the main case, not attached to the PS unit. The shaft from the PS unit goes thru it and a bronze bushing in the bottom of the tube. If the paching 'O' ring in the bottom of the unit is leaking, replacement should cure the leak. I have had more trouble with leaks around the spool valve body than at the packing 'O' ring. This still allows oil to run out the tube. Replacement of the 'O' ring packing involves removing the PS unit from the tractor. Pretty heavy and not to easy to disassemble and reassemble.
