Blake, I agree with my friend Duane there below about what that tractor was originally equipped with, which was a 12 volt coil. His advice is good and I agree with it also. It would be possible to convert to a 6 volt coil, external ballast resistor, and the start by pass system (via a start switch with the auxiliary 3rd terminal), which does give a good hot starting spark, but it should be okay as equipped. Typical things to check for a "weak" spark are first be sure the points are clean, gapped proper, not burned or pitted or heavy gray oxide coated, and replace if so. Use wire core, NOT auto suppressor type wires. Clean, crack and water free and no carbon traces in the cap. If you remove the plugs and crank her over, do BOTH produce a good visible blue and NOT a faint thin wimpy yellow spark???? If so, have the plugs in which makes compression and then see what the spark looks like if you use other plugs or have the plug wires 1/8 inch or so from the frame. The purpose of the 2 tests (with and no compresion) is to test the spark to see if its considerably weaker when cranking the engine under compression. If the sparks much weaker when cranking then with no compression (plugs out) the battery may be weak or the cables or starter bad dragging the battery voltage down. I recommend 0 Gauge battery and starter and ground cables and if she cranks too slow, you might try to charge the battery or a substitute battery or a jump to see if cranking and the spark improves. Again, a bad or weak battery or starter or cables or connections may lower battery voltage causing a weak starting (under compression) spark. You may want to remove, clean and wire brush and re tighten all battery and starter and ground cables. Other causes of slow cranking and a weak start spark may be a bad ground connection. If so, try the ground cable direct to the frame if its on the seat or battery box sheet metal currently Good or new plugs are a must, maybe try Autolite 388. SUMMARY, it originally had a 12 volt coil, check the spark with plugs out and in to see if its much weaker under compression (if so see above about battery and cables etc), check the points and wires and plugs, post back your findings and we will proceed from there. If the coil isnt labeled as to its voltage, many 6 volt coils have a primary (between lil + and - terminals) DC resistance of around 1.5 ohms while many internally ballsted 12 volters are 2.5 to 3 ohms. If you run 12 on a 6 volt coil, it will run very hot plus the points burn up quickly. Post back or e mail [email protected] any questions or if you want to change the igniiton etc. Best wishes n God Bless John T Nordhoff
