Okay...here's some answers (I think I might have caused some confusement on a couple of issues...) 1)- Clooney-- Are you saying the battery runs down just sitting? No. It holds fine for weeks at a time. I haven't put a charger on it for probably 6 months. I was only trying to emphasize that the battery seems to be performing very well, holds a charge well, and accepts a charge well, too. Doesn't use excessive water, has consistent cell to cell voltage. Doesn�t act sulfated to me. 1A) Clooney: Or what happens if you don't trickle charge it? How many starts do you get after trickle charging it? I've been running it this way and have not put a charge into it for probably two months. The only reason I think there is a problem is that it will not put out enough to keep up with the lights. 1B)- There is no draw on that battery after you shut the pony down if you aren't using the lights so you should get quite a few starts even if the generator isn't charging. If someone else were operating it and were not running lights, they would think it was working just fine. There is no draw whatsoever. I checked that using a lamp in series. If it was passing even a few MA, I'd see it. 2)- Clooney-- If your fuel gage is wired correctly you shouldn't be able to see the fuel gage drop as the cut-out opens. The fuel gage is wired [or should be] to the [GEN] terminal on the regulator or [A] post on the generator so the fuel gage should read anytime the generator is charging. When the gage quits reading that means the generator's output is below what it takes to operate the fuel gage. What I mean here is that as the engine starts, the fuel gauge comes up to reading, and when you shut down the engine, the gauge will fall to "0" as the engine comes to a stop. I took that to mean that the cut-out relay was engaging/disengaging properly. That�s why there is a push-button on the dash, right? To manually fire the gauge when the engine is not running so you can check to fuel level. 2A- Clooney: If the fuel gage is reading while the tractor is running [& if it's wired correctly] that means your generator is at least charging somewhat [enough to operate the fuel gage]. If you are trickle charging that battery so it is always up you will show a charge right after start up then it will fall to almost no charge quickly. Gauge is reading correctly. Ammeter is almost always at �0�, which would be fine for a fully-charged battery. Again, my concern if that it discharges when lights are selected. 3)-- Clooney-- are you sure the battery just isn't sulfated or fully charged so the regulator field relay isn't calling for a charge? ...To test... Remove the field wire from the regulator's [Fld] terminal then install a 6 volt test light [or bulb] between the battery terminal of the voltage regulator & the field terminal of the V/R. If those field points are working, the light bulb should light,,, then start the tractor & with it running at fast idle short the [F] post on the generator to ground,,, then with a voltmeter installed across the battery posts or from the regulator's [BAT] terminal to ground, that light should turn off when the battery voltage gets up to around 6.8-7.2 volts. By shorting & un-shorting the generator [F] post & watching this cycle a few times you can determine if the regulator field circuit is calling for a charge. As the voltage drops to below about 6.6 -6.8 volts the light should come on & as the voltage raises above about 7 volts the light should go off. A very slight glow of that light might happen at all times as there is a resistor to ground inside the regulator to keep a very slight charge in the field coils. I�ll set up to perform this test this afternoon. Questions: 1) Clooney-- Don't file the points until you verify the field points are actually malfunctioning per the above. Then try a contact type cleaner that's used on old TV tuners first. Tried some CRC electrical contact cleaner. No effect. 2) Clooney-- A badly sulfated battery will cause excessive cycling of the field points & that can cause burning problems. Is there a chance there are any other wires hooked to the field terminal of the V/R? If the cut-out & cut-in voltage is set too close together that will cause the points to vibrate & cause burning. Is there a chance you are using a negative ground regulator? Can�t say. Bought it from Ken@Classic Generator, and it worked without problems for near two years. That�s why I was quick to say that I haven�t turned any screws in the VR can. ~Additional..... Lead acid batteries can only take a fixed number of full re-charges so if you are letting it run down then fully charging it, it might be near the end of it's life cycle. I don�t think so, but I�ll try and get the battery load tested soon. It always seems to be up, just that the lights cause a discharge. ~I have been using a 12 volt generator with a 6 volt regulator on my 6 volt working Diesel for a few years now as it only gets run for less than an hour at a time & mostly at part throttle so that 12 volt generator starts to charge at a much lower RPM. Been working real good at keeping the battery up with limited short uses. I try to run it for longer periods, and I always try to keep it around 1,000 because I think it sounds smoothest right around there. ~You might have just have a bad [or sulfated] battery from sitting between uses. Probably should either load test it or replace it. If it's sulfated it will make the regulator think it is fully charged when it only gets a little surface charge [maybe that's your problem]. You will be able to tell using the light test above as that will show if the regulator is functioning as it should..
I�ll let you know the results.
