Engine Miss on 420
Bob F.
07-27-2003 06:04:52
Folks
I have a 420 (crawler actually but this is an engine question), that was only running on one cylinder. I changed the points, condesor, plugs and plug wires. The machine will now start just fine and idle on both cylinders, but when I crack the throttle open it bogs down and goes back to running on one. I suspect the valves may be sticking on one cylinder but am getting out of my league as far as mechanical ability is concerned so that is just guess on my part. Does anybody have have ideas or suggestions as to what is going on?
Thanks a bunch.
Bob F.
JB
07-27-2003 19:32:12
 Re: Engine Miss on 420 in reply to Bob F., 07-27-2003 06:04:52
Hi, take the valve cover off and check the rocker shaft at the support bolts. The rocker shaft tends to crack at the bolt hole and then the valves on that cylinder don't open completely.
Eventually the rocker shaft will break at the bolt hole. I can't remember if it was the front bolt hole that it cracked at. We had this happen twice to our 420U that we had for 10 years.
I believe the cause of the problem was insufficient oil to the front rocker arm and it would wear the shaft next to the bolt hole and eventually it would crack.
Good luck
JB
Bernie in MA
07-27-2003 18:27:07
I had better luck with Autolite 437
henry J
07-27-2003 13:24:56
Bob
It would appear a compression check would be in order when you have the plugs out. That takes care of a lot of guessing about burned valves. Good Luck
Wayne in Tn.
07-27-2003 06:58:30
Bob, first I would try opening up the load needle on the bottom of the carb. (L-shaped screw) If that don't help, I would next try a set of Autolite 216 spark plugs.
