How did it run?
MIKE HANLEY
07-26-2003 22:00:23
Those of you that recall that the battery blew up on are 630 last month. Well to make a long story longer,,,After cleaning it up,,, the touch up paint job has turned into a complete paint job. As with any clean up job to get a tractor ready to paint, and when you think you have it all cleaned up, and then find spots that you missed and after you paint you find runs of paint that need sanding, meaning you end up high pressure washing many times. Tired of laying in the mud from it's many washings, today I thought I would fire the old gal up and move it to dry ground. Hit the starter and it fired up after several go arounds of the pistons it started then would start missing and would die. After serveral times of run, miss, kill, I pulled the dist cap. That was dry as was the rotor. Pulled the dust cover and WOW!! The amount of water in that part of the dist was unbeleavable. Blew it all dry with the air hose but I'm still shaking my head amazed the it ran at all as wet as the points were. It must have taken several direct shots from the high pressure washer. I only get to putts an hour or two every couple of days on the 630 project and keep looking over at the 430 crawler and saying to my self thats the one that was to be painted this year. Not the 630. You think if I be a good boy I can live to be 100. I'll have to live that long to get everything done I want to do yet. I wonder why this 60 year old body doesn't work like an 18 year old body. The 630 was given a new paint job at the dealer when we bought it it 1976 and we painted it again it 1985 or so. This is our chore tractor and is used almost daily so I guess it was due again for paint. It's pictured in the photo gallery here with a picture taken two years ago and it didn't look two bad for a chore tractor with a 18 year old paint job.
Steve - IN
07-27-2003 05:26:21
 Re: How did it run? in reply to MIKE HANLEY, 07-26-2003 22:00:23
Mike,
Here's hopin' no more batteries blow up, especially when you're on the seat -- so you can reach that century mark. As for being good -- you're on your own.
I've heard guys sneer about Delco distributors, etc. but know from experience that if there was a Lucas distributor on you 630 -- it wouldn't have started had there been so much as one drop of moisture under the cap. That's a good story.
