Dale, The standard size rear rim would be 10x38, but I think there was an option for 11x38 around then. Under the old convention, that would mean a 10x38 tire for the standard rim, but if you're getting new tires -- you'll probably find a 11.2x38 is the size that correlates (they've changed the tire sizing convention). For a 11x38 rim, that would translate to a 12.4x38 current standard size tire. If you're shopping for new rims, you'll find that a B on 10x38's uses exactly the same rim as a Farmall H. When you get one painted silver, you can sometimes save yourself up to 10 per cent on the price versus a yellow one. If you go for the Farmall rim, then paint it yellow, no one will ever be the wiser; and you can pocket a few bucks. For the fronts, you'll probably want 5.5x16's in the three rib style. If you search, you might find the original serrated side tires; but the three rib will be easy to find. I don't know of any trick substitutes from silver, persian, flambeau, etc. to yellow for the wheels.
