JD 2010 Hydro Problem
Doc Allen
07-26-2003 08:18:39
I have a bucket loader on the front. I can't operate the three point hitch without disconnecting the hoses to the front loader. There are only two hoses. Connecting and disconnecting the hoses is a pain. Anybody have a plan?
frank
08-04-2003 19:19:44
 Re: JD 2010 Hydro Problem in reply to Doc Allen, 07-26-2003 08:18:39
I have a 2010 r/c salvage that the set up where the quik couples come out on right side of dash panell, i will look to see how they are routed
Bob Clark
07-27-2003 08:58:42
Have heard this question before. Had a 2010 utility equiped with a 46A loader of the the show room floor back in '61. Can't remember the exact routing but if you can get hold of a partsbook you should be able to figure out the connections. There is a "power beyond" port under the console. The original routing had oil lines routed out the right side panel. When the loader was off you had to connect the hoses to complete the loop. With this setup every thing would work although the loader would steal the oil from the remote or 3point first and slow their operation. Hope this helps.
Doc Allen
07-27-2003 04:28:20
Woodman and Ron, Thanks for the reply I think you are right about the return line I will try that. Seems logical now that I think about it. I've tried almost everything else. Thanks again. Doc.
Woodman
07-27-2003 03:34:25
I have a 3020 that I was told by JD dealer to route the return line in the oil filter cover. I drilled and tapped for 1/2 " pipe fitting and put a quick disconnect on it. They told me thats the quickest way for the oil to return otherwise I would run out of oil when using loader and 3 point at same time. It works very well. I don't know if 2010 is the same but you could ask a dealer.
Bob
07-27-2003 18:53:27
 Re: Re: JD 2010 Hydro Problem in reply to Woodman, 07-27-2003 03:34:25
2010 is an OPEN CENTER gear pump, 3020 is a CLOSED CENTER piston pump. Power beyond valve setup is totally different between the two systems. I know how to do it on the 3020, etc., but NOT the 2010, and I suggest before messing with the 2010, BE SURE you have the correct info..
Maybe search out a dealer with an older mechanic that's been around for a while.
Tom in Mo.
07-26-2003 19:11:58
Did you check the fluid level? It could be lot's of things but check the fluid first. Next would be replacing the hydraulic filter and fluid change. It doesn't make sense that the remote hydraulics would interfere with the three point unless you were low on fluid.
Doc Allen
07-26-2003 19:25:22
 Re: Re: JD 2010 Hydro Problem in reply to Tom in Mo. , 07-26-2003 19:11:58
Tom in Mo Thanks for the reply. Put in new clutch and while doing that rebuilt the hydrolic pump, changed fluid, and cleaned the filter but still can't operate both together. I have three select levers, one for the front bucket and the others for the three point hitch. One of the hoses is routed back to the fill plug hole. Maybe the routing is wrong. I have to brace the bucket cylinders in the up position to releve the pressure and disconnect the hoses so the three point hitch will work. With the bucket braced in the up position I can then reconnect the hoses with ease, but still apain in the neck. No one in Michigan can figure it out. Thanks.
