720 diesel
Tom
07-25-2003 21:12:49
My late model 720 diesel has a steering problem. The power steering seems to fail occassionally for no consistent reason. The failure may occur at slow idle, fast idle, warn engine, cold engine. I replaced the fluid with JD 1960 and older steering fluid. No help.
What do you experts think?
I also have a leak around the governor housing. A friend suggested that I could remove the three bolts from the housing, loosen the water pump and slide the shaft far enough forward to use form a gasket. I can't get the shaft to slide.
Any ideas here?
Clooney
07-26-2003 19:28:19
 Re: 720 diesel in reply to Tom, 07-25-2003 21:12:49
Tom, what do you mean by failure? If it quits all together & won't come back until you restart the tractor look at the cooling fan to see if it stops spinning when the P/S quits, maybe your fan shaft coupling splines are worn out. ~If the fan doesn't quit turning you might want to see what the P/S pressure is running at & maybe do a vane leakage test. ~You could have anything from a broken vane pin, to a loose steering valve fork nut, to a sticking sleeve cam, to failing sleeve pin, to ?
~On that governor leak? Where is it leaking on the governor housing? Are you sure it isn't the transfer pump weep hole leaking diesel oil at the pump & flowing out around the governor?
