JD 2240 Hydraulic
Jerry
01-15-2004 17:11:01
Tractor: Late 70's JD 2240 w/hydraulic reverser
Symptom: Hydraulic chatter, intermittent power steering and clutch failure.
Surface reason: Pressure pump is cavitating
Underlying reason: ?
I've had it all apart & back. Pressure pump requires 30 or so #s supply pressure to open intake valves which has to be supplied by transmission pump. Transmission pump is worn but within tolerance, all plumbing and gaskets are good. Is there a valve someplace that should provide measured back pressure in the supply ciruit? What am I missing...
Jerry
John
01-15-2004 18:25:12
 Re: JD 2240 Hydraulic in reply to Jerry, 01-15-2004 17:11:01
I`m assuming that its equiped with a live independent PTO. Could be that the PTO brake is beyond worn and bypassing hyd. oil. This puts small air bubbles in your hyd. oil and creates cavitation. More noticable after a few minutes of the tractor running. Compare a cold oil sample to a warm one after the tractor exhibits the symptoms under a magnifying glass. Also look to see if the PTO turns when the pto is disengaged.Thats a symptom. By the way,that transmission charge pump only works when the clutch is engaged. Extended hyd. operations with the clutch disengaged will cause temporary hydraulic funkiness. This doesnt sound like your problem. Is there a loader with a closed center valve on this tractor? Maybe Davidval will be able to post a more educated response with a better diagnosis.
Jerry
01-15-2004 19:14:34
 Re: Re: JD 2240 Hydraulic in reply to John, 01-15-2004 18:25:12
PTO on this Tractor is on the left side of trans near back of running board and requires the clutch to be disengaged. This tractor has 3 clutches, dry disengages engine from everything, 2 wet clutches for foward/reverse, these are disengaged by depressing foot pedal part way and switched w/dash lever. If there's a brake on the PTO it would have to be in the back of the trans. There is a loader with a closed center valve that gets pressure from fitting on side of trans just behind trans oil filter.
In the begining problem went away after a minute of running, shop told me the cause was a split line in the transmission that alowed the reserve tank to drain overnight, didn't find that but did have a bad seal and gasket. It's now become a problem anytime engine revs are low.
anything else I can tell you?
Jerry
david val
01-15-2004 23:42:04
 Re: Re: Re: JD 2240 Hydraulic in reply to Jerry, 01-15-2004 19:14:34
if the problem still exists, and to avoid a long post email me for circuit exlaination and way to test the system.
david
John
01-15-2004 23:21:07
That tractor has a "live pto" not "live(two stage foot clutch) independent" which is hydraulicly actuated and stopped with a lever or knob between the two transmission gearshift levers.
That eliminates the worn PTO brake theory. I guess i`m stumped forthe time being. Perhaps Davidval will post a response and give us both some insight.
