Curious about JD B
Latta
07-25-2003 17:39:18
Back in the early 80's I helped a neighbor with his haying. He pulled his 7' New Holland haybine with a WFE JD 530. He mentioned that a late model JD B had enough power to run his haybine. Is this true? I have read in the Farmall archives that the Farmall H is considered big enough to power a haybine and it has about the same PTO horsepower as the B.
RayP(MI)
07-26-2003 08:27:17
 Re: Curious about JD B in reply to Latta, 07-25-2003 17:39:18
Running a '49 B on a NH 268 baler and pulling a loaded haywagon behind, also run a Oliver 60T baler in same configuration. I was suprised the PTO capability! My Farmall 200 doesn't do nearly as well on the Oliver baler, and wagon on behind is asking a bit much!
SamH
07-25-2003 20:16:47
I have not tried to pull a 7' haybine with a B JD or H Farmall, but have done other things with them and have pulled haybines with other tractors. Based on that, I would say the B will pull the 7 footer if the hay is not too heavy. I was never particularly impressed with the PTO performance of the B or H Farmall, but the 530 is a different story. There is a lot of difference between a B and a 530. Just an opinion. Maybe somebody on here has done this and can tell us how it worked.
RLA
07-26-2003 09:07:17
 Re: Re: Curious about JD B in reply to SamH, 07-25-2003 20:16:47
I have mowed many acers of good hay with a 1950 cyclone B, using a 1209 J/D & 489 New Holland Haybine's. 3rd & 4th gear on the level fields if you kept it cranked up. A few times down into 2nd on the hills but got the job done. We run a dairy farm, so this isn't poor hay?
