1020 carb question
rem0h
07-25-2003 11:26:38
i have a 1020 that sometimes floods and runs rich. when it does this i can completely close the needle valve and it will still run. after a while it starts leaning out and i have to open tne valve again and it works fine for a while. this is not a float problem and the needle valve is new. it has a new filter on it as well. any ideas? i can get a new carb for $229 on this site. has anyone had experience with these carbs? are they ok?
Duane Larson
07-25-2003 20:20:04
 Re: 1020 carb question in reply to rem0h, 07-25-2003 11:26:38
rem0h,
It sounds like a fuel level problem - to check the true fuel level, locate a 1/8" pipe thread hose barb and a foot-long piece of plastic tubing which fits over the barb. Remove the drain plug on the bottom of the carb and replace it with the hose barb. Turn on the fuel and the fuel level will rise in the plastic, so you can tell the true fuel level. It should be about 5/8" below the top of the bowl, and the float should be approximately level with the top casting when held upside down. There are several things which could cause a high fuel level besides a bad float - the bowl vent being top on my list. Reply back with what you find with the fuel level, both static and after the tractor has run, and we can try to help further.
Rem0h
07-26-2003 07:14:34
 Re: Re: 1020 carb question in reply to Duane Larson, 07-25-2003 20:20:04
Duane, great idea. Just so happened i had 2 of those fittings on my desk. It does pay to keep stuff like that (ha ha). While running, the bowl was nearly empty and when i turned it off the bowl filled within 1/2 inch of the top. Maybe thats a little too high. I did notice that the engine started better with the tube installed. It required a little choking, where as it usually does not and will flood easily. I am not familiar with how the carb bowl vents and how that works. More info would be great.
Rem0h
07-26-2003 08:50:49
 Re: Re: Re: 1020 carb question in reply to Rem0h, 07-26-2003 07:14:34
I got more information, hope this makes sense to you. I decided to try a little mowing with the fuel level tube installed (with the tube open to atmosphere). At wide open throttle all the fuel was sucked out of the tube and the engine was missing and making black smoke like it was flooding. I slowed the engnine down to about 1750 and the fuel level came back up just a little - maybe 1/4 inch in the bottom of the bowl and the flooding stopped. Then at low idle the bowl filled up to within 1/2 inch of the top of the bowl and was running smoothly. --- Why would the engine seem to be rich and flooding when the there is no fuel in the carb bowl? With the throttle wide open it did seem to help a little with the needle valve closed but it was still smoking and missing. It does not do this all the time it just has an occasoinal fit. ---
ET
07-25-2003 13:01:30
Try setting your float leval a little higher than the specs. call for.The specific gravity of gas today is not like it was when that carb. was built. Let us know if this helps.
