730 D ES DECOMPRESSION ADJUSTMENT
JDJACK
07-25-2003 10:09:09
I want to check the depression adjustment. could somebody tell me how to check it and what the spec is for clearance. I believe that the valve cover will need to be removed. thanks.
F-I-T
07-25-2003 10:27:16
 Re: 730 D ES DECOMPRESSION ADJUSTMENT in reply to JDJACK, 07-25-2003 10:09:09
Jack:
Roll it over to #1, make sure there is free play in the tappet of the #1 exhaust valve (indicates that the decompression linkage is not having any effect). Using a dial indicator, set it on the valve retainer, not the tappet lever, set dial to "0", and engage the decomp linkage. The valve should be depressed by .055-080". If not adjust linkage accordingly.
This is out of the 70D book, but I'm pretty sure yours will be the same values. The main thing here is to have it clear during normal operation, because you could easily burn a valve if you have the exhaust valve hanging slightly open on the decomp linkage.
Frank-in-Tallahassee
70D // 855
