1951 B Paint color in starter cavity
Texasdeere
07-24-2003 20:05:24
I have a question: I was changing out the starter on my 51 "B" and noticed the whole inner cavity, where the starter fits up under the engine, is painted bright yellow. I am just curious what this might signify, a re-built engine?, maybe an original engine?, creative painting?
I don't have a clue, please let me know what you think...thanks
Bob-
07-25-2003 22:40:07
 Re: 1951 B Paint color in starter cavity in reply to Texasdeere, 07-24-2003 20:05:24
It is a primer or sealer that you will find inside of all Deere castings.
Larry806
07-25-2003 17:08:27
That is lacquer primer on the inside of the cast iron. Cast being very porous oil will eventially soak clear through it. That is why all engine blocks, transmissions, and rear ends are painted inside with it. That is the only thing I ever learned, the night I went to college when my brother was sick. ha! ha!
Cragi
07-25-2003 15:56:20
Mine is all yellow inside too. There is yellow under the green paint here and there on the outside of the tractor too. Just a primer or sealer they used at the factory.
JDGnut
07-24-2003 20:12:11
Not to burst your bubble... Its just primer that was used on most of the waterloo tractors..Most of the JD's are that color on the inside too...
JDGnut
