JD 420 Lawn tractor
Charles Wetheri
07-24-2003 19:33:56
I aquired a 420 lawn tractor that runs great for maybe 15 minutes, cuts grass great then shuts down. Wont start until engine cools down. I've replaced the air filter, fuel filter, ignition coil (one side seemed slightly fouled), & spark plugs. Oil OK. It seemed to run better but then did the same thing again. Dont know where to go from here. It has the 2 cylinder Onan P220 engine. Any guidance would be appreciated.
rusty akers
10-24-2005 17:36:40
 Re: JD 420 Lawn tractor in reply to Charles Wetherington, 07-24-2003 19:33:56
I also have a 420 with the same problem. It will run for 15/20 minutes and shut off. I have good fuel with no spark at the plugs. I have electronic ignition on this. any suggestions.
thanks
Nick koeppe
08-05-2006 21:56:45
 Re: JD 420 Lawn tractor in reply to rusty akers, 10-24-2005 17:36:40
Your coil could be bad, bad wires, bad plugs, could be that water in gas or it could need a carb kit or it could be that gas lines are closeing
feel free to email with questions i will try my best
[email protected]
PLEASE put onan P220 in subject box.
Roger
07-25-2003 19:07:09
My guess is the valves are sticking. This was a problem on some of these motors. Try putting some transmission fluid in the gas, you can also put some in the curbutator. Also keep the air cleaner clean.
JDOUG
07-25-2003 05:19:03
Couple of questions 1st. Does the engine only shutdown while mowing? When it dies, does it have spark at the plugs? Will it crank over right away after it dies? If it wont crank over, it could be the elec. clutch coil failing and tripping the circuit breaker. If you dont have any spark, but the engine cranks, it may be the ignition points. The early 420's had ignition points while the later were electronic. The points on the eraly engines were located under a cover on top of the engine in front of the air filter. The condensors were orginally located there also and would overheat and cause loss of ignition. If you have point style ignition with the condensor under this cover, relocate it up by the ignition coil.
720diesel
07-24-2003 19:41:29
you might want to change the points and condensor. my jd 400 did the same thing until i changed them. hope this helps!
