CLOONEY PLEASE HELP 1928 JD D'
MIKE STEWART
07-24-2003 11:22:03
MISSING OIL LINE. HAVE BOTH MAINS ,AND LINE TO TAPPETS ,ONE MORE HOLE, NO LINE , WHAT IS IT ,WHERE DOES IT GO ,WHAT DOES IT LOOK LIKE. LOST PLEASE HELP!!!!! !!!!!
Bob-Wyo
07-25-2003 19:56:06
 Re: CLOONEY PLEASE HELP 1928 JD D' in reply to MIKE STEWART, 07-24-2003 11:22:03
Mike, NigelB is right on the money, I checked my 29 and it has 3 lines just as he says. If you have the decal for the back of the gas tank it shows oil flow.
Sorry for all the confusion, but told you have 35 and 38 on the brain, 31 to 34 is a whole different setup then change again for 35 up.
Good luck,
Bob.
PS Ole Wille can still do it up right.
Mark
07-25-2003 12:21:33
Bob, I saw Willie in Des Moines tuesday night. He was awesome....
Bob Wyo
07-24-2003 14:27:32
MikeI agree with Clooney, I'm thinking here (very bad for all)(been working on 35 & 38's, so brain erased all other's)it's a smaller line that tee's off at the very left hand rear, off the left hand main line. and up to the RED HEAD oil pressure indicater.
But you need the BIG LINE that comes across LOW from the pump too.
Now for Don's 6th line, I don't know what we are missing here, but bet Don's pic will show it. Mike I have a junker 29 that I will look at and hope some of this is still there,as I could be way off base here. bear with us, I would email you tonight but got to go hear WILLIE NELSON sing. Bob
Clooney
07-24-2003 12:47:35
Mike, you guys have come up with some beauties lately.
~It's been a while since I have been into the oil system on a 28 D. ~I'm thinking it must be the line to the oil indicator. As for what it looks like? That I can't remember but it would probably runs from that open hole to the oil indicator on the case. Just make sure it clears the crank throws...
Don
07-24-2003 12:34:08
Mike, I have a diagram of the oil lines that shows six lines including the line to the tappets. Could you be missing more hardware? Some of the guys here will help you get it back together, they know these tractors inside and out.
MIKE S
07-24-2003 18:53:09
 Re: Re: CLOONEY PLEASE HELP 1928 JD D' in reply to Don, 07-24-2003 12:34:08
I WOULD LOVE TO SEE YOUR DIAGRAMS ON THIS,BECAUSE MY TRACTOR DOSN'T MAKE SENSE .I HAVE ONE LINE COMES FROM OIL PUMP TO PRESURE GAUGE,FROM THERE ONE GOES TO LEFT MAIN,ONE GOES TO RIGHT MAIN,THEN ONE MORE HOLE,IT NEEDS TO GO TO GOVENOR BUT THERE IS NO WHERE FOR IT TO HOOK TO HOUSING OR OTHERWISE .IS IT POSSIBLE THAT IT JUST STUBS OUT AND RUNS ONTO THE GOV GEAR AND CLIMBS OVER GEARS INTO HOUSING DRAINS INTO TROUF AND RUNS TO TAPPETS ????? ????? ?????
Clooney
07-25-2003 03:15:24
 Re: Re: Re: CLOONEY PLEASE HELP 1928 JD D' in reply to MIKE S, 07-24-2003 18:53:09
Mike, feel around up under the main case where the governor bolts down. If I remember correctly there is an oil jet sticking through the case that needs an oil line hooked to it. The early governors don't oil directly but spray oil from a jet type fitting sticking up through the main case. I'm not positive on the 28 [it's been a while] but I think it has that jet....
MIKE S
07-25-2003 07:57:22
 Re: Re: Re: Re: CLOONEY PLEASE HELP 1928 JD D' in reply to Clooney , 07-25-2003 03:15:24
LOOKED, NOT THERE. UNLESS SOMEONE TELLS ME OTHERWISE,I THINK I WILL JUST STUB A LINE OUT TO SPRAY ONTO THE GOVERNOR GEARS AND HOPE FOR THE BEST. STILL LOST!!!!! !!!!!
nigelB
07-25-2003 10:43:25
 Re: Re: Re: Re: Re: CLOONEY PLEASE HELP 1928 JD D' in reply to MIKE S, 07-25-2003 07:57:22
Well here goes line from pump to oil pressure indercator casting,one tee of to left main and one tee of to right main. the hole in the casting to which you seak an answer is just plugged of with square end plug like a mini oil drain. the governor is purley a splash feed not done by via spray line in that era. the hole is for a drilled side hole like on a carb. il send you a pic for referance mike. regards nigelB
Mike S
07-27-2003 09:03:50
 Re: Re: Re: Re: Re: Re: CLOONEY PLEASE HELP 1928 J in reply to nigelB, 07-25-2003 10:43:25
THANKS TO ALL THE INPUT I THINK WE CAN MAKE IT WORK NOW .THANK YOU TO ALL.IF WE COULD JUST FIND SOME 12INCH CLUTCH PARTS????? ????? ??
