820 System Voltage
Gary U in NJ
01-15-2004 14:44:40
Well, I'm caught a bit prematurly. I'll be receiving my 820 Blackdash on Saturday (I've been wanting one for a long time and its finally come true). The only problem is that I haven't had the chance to get the Operators & Service Manuals from Deere.
So I need to get a battery (or batteries?) so it can be driven from where it will be off-loaded. What size, votage and quantity. I'm guessing its a single unit to power the pony?
buickanddeere
01-16-2004 05:56:04
 Re: 820 System Voltage in reply to Gary U in NJ, 01-15-2004 14:44:40
Make certain the voltage regulator is set for 7.1V, measure at the battery at full throttle in winter time. And 6.9V in hot weather when operated for extended intervals. As Brandon mentioned use the decompression lever and the diesel throttle shut off in sequence when starting. That's why Mother Deere put them there. Yes I know lots don't and electric two cylinders get started all the time on full compression with the fuel already on. They should be rotated a few rev�s without compression too. Roll the diesel without compression and fuel until oil pressure appears. Apply compression for a couple of thumps then apply fuel. Shut the starting engine fuel valve if equipped and let idle for 30 seconds before cutting ignition. Enjoy.
Gary U in NJ
01-18-2004 14:16:10
 Re: Re: 820 System Voltage in reply to buickanddeere, 01-16-2004 05:56:04
Great information on the voltage, it is very appreciated!
Gary
Brandon
01-15-2004 18:38:28
As the others said, the battery is a six volt, hooked positive ground.
If you need any help with the starting procedure, let us know. Unlike the 70, the 820 uses two levers to engage the pony (both are by your left foot). The left lever is for pony/flywheel engagement, and the right lever is for decompression.
Good luck!
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
Gary U in NJ
01-18-2004 14:17:33
 Re: Re: 820 System Voltage in reply to Brandon, 01-15-2004 18:38:28
Thanks for the advice! Its a very naked feeling not having the operators manual.
Gary
Ralph
01-15-2004 17:07:10
I always go to my JD dealer and buy their standard 6 volt. One is needed. Are you sure the starting engine is running? I like F.I.T's idea. By the way are you acquainted with the starting procedure? Right now I am having a senior moment and can't tell you which lever is the decompression and which is the transmission-clutch lever(after owning one for 5-6 years???). If you want detailed starting instructions give me a shout and I will see if I can learn how to operate my new scanner and send you a page out of the operators or service manual.
Gary U in NJ
01-15-2004 18:34:34
 Re: Re: 820 System Voltage in reply to Ralph, 01-15-2004 17:07:10
Ralph:
Many thanks for the reply! No real guess on the pony (I've been promised that both engines run good, but who knows). I'm going to remain optomistic, and at worst I might be in for a pull start.
Gary
F-I-T
01-15-2004 16:08:29
Gary:
If it's a pony start, it's the same battery as your 70D uses, and you might be able to just swipe that one for the day. Otherwise, I think a Sched. 1 is the size.
Frank-in-LA
Gary U in NJ
01-15-2004 18:39:37
 Re: Re: 820 System Voltage in reply to F-I-T, 01-15-2004 16:08:29
Hey Frank!
Happy new year!!!
Hope all is well on your end, what's the latest? BTW, I hope your enjoying the warm (or at least warmer)weather in Florida - it is so cold here I can't stand it.
Appreciate the feedback, can't wait to get it home. The 70D is slowing going back together, hard to assemble in this cold and work seem to get into the way of everything fun.
Gary
blksmok
01-15-2004 20:02:13
 Re: Re: Re: 820 System Voltage in reply to Gary U in NJ, 01-15-2004 18:39:37
Gary....what did you determine was the cause of the problem(s) you had with your 70D??? Just curious.
Gary U in NJ
01-18-2004 14:19:25
 Re: Re: Re: Re: 820 System Voltage in reply to blksmok, 01-15-2004 20:02:13
I'm still in the rebuild stage. Just about to bolt down the flywheel and install all the intake and exhaust manifolds.
