CLOONEY, HELP
JIM
07-23-2003 17:48:20
I have a 1932 JD GP that has the 3 speed gear box. Low, Mid, High and the problem I am having is that frequently when shifting into high gear then engage the hand clutch the tractor will not move. Through investigation I found that the gear box will have both mid gear and high gear engaged at the same time. If I shift into low then back to high it is fine and works perfectly. I am concerned about gear damage.
Clooney
07-23-2003 18:18:47
 Re: CLOONEY, HELP in reply to JIM, 07-23-2003 17:48:20
Jim, it sounds like you have internal shifter wear, or trans bearings going bad. I'm afraid I can't give you specifics on that 3 speed GP. I haven't been into a GP trans in at least 20 years..
~Maybe someone that has done one recently can give you some more specific information..
