730Diesel help needed
MIKE HANLEY
07-23-2003 16:09:42
Had a guy call me asking if I knew how to set up the horsepower on a 730D. We have two 730D,s and the guy thought I would know. I don't know. As far as I know both of ours are stock and I never put them on a Dino. NEED DETAILS Repeat Details. Thanks MIKE HANLEY
Gpower
07-23-2003 20:04:10
 Re: 730Diesel help needed in reply to MIKE HANLEY, 07-23-2003 16:09:42
What exactly are you needing to know. Are you wanting more power?? More smoke?? More fuel?? I can help you out, just let me know what you are needing to do.
Gpower
MIKE HANLEY
07-23-2003 20:37:17
 Re: Re: 730Diesel help needed in reply to Gpower, 07-23-2003 20:04:10
The guy wants more power. He was telling me he had heard of of a guy in MO. that did something or sold something that increased the HP without the smoke. The factory spes saids that a 730 should crank out 57.?? something HP on the dino. He thought the guy in MO could have a 730 crank out close to 65 HP.
Gpower
07-24-2003 09:35:44
 Re: Re: Re: 730Diesel help needed in reply to MIKE HANLEY, 07-23-2003 20:37:17
About the only way to increase your HP is to turn up the fuel a little, unless you want to start spending the bucks. Although by turning up the fuel you will have an increase in smoke under load. Idling around half throttle half load you will not notice any changes in smoke. PRobably the best thying to do is have the pumps checked and rebuilt/cleaned as well as the injectors. This will ensure the proper calibration of the unit and ensure that they are functioning well. Also check the air cleaner, diesels like the air and need a good supply of it. I can check the pumps and injectors out if need be. Hope this helps,
Gpower
Tom
07-24-2003 20:06:10
 Re: Re: Re: Re: 730Diesel help needed in reply to Gpower, 07-24-2003 09:35:44
Gpower, how much pressure do I need coming out of the transfer pump on my 720? Ive had the pumps and injectors gone through, timed it, have good compression, and played with the smoke screw on the dino and can't get over 40 HP. It doesn't have that "cracking" sound coming from the exhaust like a diesel in good shape. Any ideas?
Gpower
07-25-2003 16:13:14
 Re: Re: Re: Re: Re: 730Diesel help needed in reply to Tom, 07-24-2003 20:06:10
Hey Tom, I just got around to the keyboard again, I should have your question pretty well answered on the first page, under the question for JDGnut on the first page. If you need more help or specs, or how to get more horses, drop me a line. Thanks
Gpower
F-I-T
07-25-2003 09:06:59
Tom:
I'm sure you know this, but timing is everything. Make doubly sure that injector timing is RIGHT ON. On those where they didn't really "Crack!", it was just a bit off on timing.
I trick I use to take my bias out the equation is the roll the flywheel over until I think the injector mark is lined up in the window, THEN look at where the timing mark on the flywheel is relative to the static mark. Measure the number of flywheel teeth in 90*, divide this by 90, and get the # of degrees per tooth. Then you'll know how far your timing if off. For an even better test, have one or more friends try it. If you're right on and it's not cracking right, consider having the pumps and injectors re-checked for cracking pressure.
Frank-in-Tallahassee
70D // 855
JDGnut
07-24-2003 20:15:14
Tom.. it depends on which set up have.. but it should be min of about 45 psi... run about 60 psi on my 70D with the stock gear pump... Does your 720D have the return in the top of the pump cover??? JDGnut
MIKE HANLEY
07-24-2003 10:34:40
The guy just had it overhauled at a JD dealer and the pumps and injectors were send out and rebuilt. But he went to a show and heard about this guy from MO. I told him his best shot is to keep asking abound at shows til he finds the name and phone number of the guy in MO.
MIKE HANLEY
07-24-2003 11:00:16
 Re: Re: Re: Re: Re: 730Diesel help needed in reply to MIKE HANLEY, 07-24-2003 10:34:40
The tractor is putting out all the factory horses, but since he heard about the guy in MO, he was hoping I would know who he is or what he did. I told him I would try to find out here. Thats about all I can tell him I guess. Thanks MIKE
