JD 450G Steering Clutch question
George
07-23-2003 13:08:44
I have a JD450G that works fine. I've noticed that in the last few weeks the steering clutch levers do not 'snap back' after a turn. The operator has to push them back. I've looked for any kind of return spring or device that might be broken or missing but there doesn't appear to be anything like that.
Any ideas on what I should do? I'm afraid I might be dragging brakes or something that is causing pre-mature wear when it is operated in this mode. I see that there is a clutch adjustment screw inside the inspection cover just above the sproket on each side. Someone has suggested that the clutches need 'tightening'. Does this sound reasonable?
Any advise is appreciated.
George
RexB
07-24-2003 09:45:08
 Re: JD 450G Steering Clutch question in reply to George, 07-23-2003 13:08:44
Your newer than my JD350, this fm 350 shop manual:
-Pivot pins/bracket worn: crankcase oil (SAE30) or replace.
-Return springs weak or worn: replace.
While you're in there, are the adjustments/free play right? My (old dry clutch) has outlasted the hour meter by doing the sked tuneups. Sure like those 450G's :-)
Jonathan
07-23-2003 14:22:31
Those adjusters are to tighten the brake bands. If the machine turns ok then they probably do not need adjusting. You may want to just check all the linkage to be sure there just isnt debris or similar causing this. If you remove the panel behind the seat and then remove the bolts that hold the seat platform/battery box down , you can slide the whole seat platform rearwards and see the steering linkage. Remove the forward floor boards also. Maybe start removing the linkage joints to see exactly where the binding is occurring. This might give you somewhere to start anyway...
