4020 Won't Shut off
Jason
07-23-2003 13:01:03
I was backing a full load of hay into barn and went to idle down to begin backing up and the throttle stuck darn near wide open. I pushed on the brakes and let out on the clutch and that seemed to help bring it down enough to use. Then it happened again, so I tried to just shut it down using the throttle column lever to see what the problem was and it would idle down but not shut off. I tried pushing on the pump lever to shut it off, nothing, it finally just died and I couldn't get it restarted. I should tell you that I just got this tractor about 3 months ago on a trade, and it had been sitting for about 3 years prior to that. I changed the fluids, put new diesel in charged the batteries and she ran fine until just this other day, (except at times throttle response was a bit sluggish). Any ideas on the problem?? Thanks in advance, I really like this tractor.
Dale in IN
07-24-2003 06:41:33
 Re: 4020 Won't Shut off in reply to Jason, 07-23-2003 13:01:03
Check your foot throttle pedal. Sometimes they stick and will not let you shut down. Just reach down and pull up on it with your hand.
DON
07-23-2003 15:03:14
THE PUMP GOVERNER RING HAS BROKEN AND THE PIECES ARE JAMMING THE METERING VALVE . THE INJ. PUMP NEEDS TO BE OVERHAULED. SOME $250-300 SHOULD BE IN THE BALL PARK.
