Help Removing MT Steering Column
Larry Marshall
07-23-2003 11:29:00
I have been trying to disassemble the steering column on my MT but having no luck. I am swimming in Kroil, but the shaft refuses to come out of the tube. I am considering a piece of rebar or some other type rod and attempting to drive it out from the front end. Anybody have any ideas or success stories?
JH
07-24-2003 10:19:11
 Re: Help Removing MT Steering Column in reply to Larry Marshall, 07-23-2003 11:29:00
Are you speaking of the adjustable shaft that moves fore and aft inside of the steering tube? If so, then there is a roll pin through it, to prevent the inner shaft from coming out. It must be pulled aft far enough for you to get to it and knock it out by way of the small hole in the steering tube itself. You may have to drill the roll pin out. Once removed, the adjustable shaft should pop right out, unless of course someone has welded it as previously stated. If that is the case, then you'll have to get past the weld before pulling the inner shaft aft. Someone welded one on one of my Ms. Probably because they didn't know any better. The same guy is probably responsible for throwing away the metal washer that sits below the oil filter inside the housing, and often sticks to the bottom side of the paper element. That washer happens to regulate oil pressure. I was lucky to find one. Good luck.
RK
07-24-2003 06:26:09
I have two M's, both steering shafts have been welded solid by some clown. Was wondering if you may be in the same boat. I will have to grind and file away at mine to get them apart.
tom
07-24-2003 08:33:57
 Re: Re: Help Removing MT Steering Column in reply to RK, 07-24-2003 06:26:09
RK,
I know it is frustrating when someone has welded or bastardized a tractor [tractor part]. However, the steerting mechanisms on these M's/MT's were not too great and slipped alot. To have these steering systems running properly, they require alot of mgmt for safety purposes. Those welds "may" have saved or kept your "M" from doing something that you did not want it to do...even Deere admits the designs were bad and changed/discontinued them permanently. As a result, there may be a clown out there that prevented an injury to you or the family...something to think about!
Larry
07-24-2003 06:32:48
I don't think so, no sign of welding. I have two of them I am trying to turn into one.On one I can get it to move a few inches, but the other one is pretty much stuck solid.
bruce
07-23-2003 17:00:53
The shaft has a groove pin in it and it's in line with a hole in the tube.Drive the pin out and it should come out. (479)965-2994
Larry
07-23-2003 19:23:43
 Re: Re: Help Removing MT Steering Column in reply to bruce, 07-23-2003 17:00:53
I can't get the adjustable shaft out far enough to get to the groove pin. In fact, I can't get it to budge at all..... .
will
07-23-2003 14:09:37
i have a 40T and i always had to remove the steering wheel and slide it forward through the pedestal.
