JD 50, Traction Needed....
Tye
07-22-2003 18:21:53
I entered in my first tractor pull last Sunday. I put myself in the 6,000 lbs class and did ok. I had plenty of power just couldn't get that power to the ground. I have fluid in the tires and they are inflated too much--I know this for sure. Do most pullers drain all fluid from the tires and just fill them with air and add dish wheel weights? Can only air filled wheels support all that extra weight in the rear. Sorry if these questions are trivial but I don't know much about tractor pulling. We've always had tractors weighted with fluid as well. Thanks for any help here.
JDVan
07-22-2003 18:35:48
 Re: JD 50, Traction Needed.... in reply to Tye, 07-22-2003 18:21:53
What weight did you end up with you on the tractor? I would suggest trying to get your combined weight under 5000 lbs as tractors with much more HP and traction can also pull in the 6000 lb class such as my 1954 60.
The key to pulling is balance. Raise your hitch to as high as the rules allow but still try to keep your front end just litely on the ground under a heavy pull. Reduce the air pressure in your rear tires to 6 to 9 lbs depending on whether the track is loose or hard. Watch what the lugs do to the track under load and adjust tire pressure accordingly. Maybe pull in 2nd gear on a very loose track and in 1st gear on a very hard track.
