B compression
George H
07-22-2003 17:15:22
What should be compression be (in pounds with a tester) on a 50's era B? Help always appreciated !!
tom
07-23-2003 05:49:27
 Re: B compression in reply to George H, 07-22-2003 17:15:22
George,
I can not tell you the specifics of the B, but in general, you should have @ least 60-70lbs worse case, 125-130lbs best case. However, the real issue is how much is the delta between Cyl-1 and Cyl-2? 0-5lbs great 6-10 not bad, 11-15 something will need to be done sometime in the future, 15+, there's a problem somewhere...
hope this helps,
tom
Jon
07-23-2003 13:54:19
 Re: Re: B compression in reply to tom, 07-23-2003 05:49:27
According to the I&T manual, the "B" compression should be as follows;
All-Fuel 70 PSI
Gas only 110 PSI
Taken from page 5 of I&T manual #JD-4
JC
George H
07-23-2003 18:40:23
 Re: Re: Re: B compression in reply to Jon, 07-23-2003 13:54:19
Thanks guys. Not in as bad shape as I thought.
