40 jd b front wheels
scott h
07-22-2003 15:49:21
I have a 1940 styled B with miss matched front wheels, they are both 15 inch 6 bolt but one is solid and one has four slots around the outside edge, I was wondering which one correct. thanks
Bob Collins
07-23-2003 13:02:48
 Re: 40 jd b front wheels in reply to scott h, 07-22-2003 15:49:21
I'm going from memory here, but I think the AB1023r wheel is correct and changed from a solid wheel to one with four slots and no part number change in 1941. the wheel is not reversible and that makes it different from the 1262 wheel. Seems like 2 Cyl mag had an excellent article about the early styled B a number of years back and spelled it out very well.
JDVan
07-22-2003 21:05:01
I just found another reference for 15" rubber tired wheels for the B. JD F219 dated 11-47 - "Parts Catalog Covering Wheels" from John Deere Waterloo Tractor Works.
It only references the following 15" wheels appropriate for a 1940 B:
AB1023R ser # B29631-B153375
JD1262R Ser # B1000-B200999
Since the reference books show these part numbers with and without slots, is it possible JD changed the rim w/o changing the part number? Or is AB1023R the solid one and JD1262R the one with slots? The references are not clear.
Mark J
07-22-2003 17:45:39
It is my understranding that sometime in 1937 Deere went to a solid front rim and used the same rim through 1940.
JDVan
07-22-2003 20:43:43
 Re: Re: 40 jd b front wheels in reply to Mark J, 07-22-2003 17:45:39
I have just looked up the front wheel options in my Repair Catalog 49R d ated April 15, 1940 and 58R dated August 15, 1943. Both show AB1023R starting at ser # 29631 but the picture of the actual wheel changes from a solid wheel to the one with 4 slots in the 1943 edition. JD1232R is also referenced in the 1940 catalog with the same picture. A solid center. Then in the 1943 edition, they show the 4 slot version with also the part number JD1261R but it was not supposed to be used on the B or BN. In PC-330 they only mention AB1023R for 15" applications and show a picture of the 4 slotted wheel. I cannot come to any firm conclusion based on these three references. Find a match to one of them and call it appropriate? :-) I do know my 1940 Slant Dash B has the two 4 slotted wheels on it and they look very original at ser # 89xxx.
JDVan
07-22-2003 16:36:58
I own a 1940 Slant Dash B Ser # 89xxx. It has matched front wheels with the 4 slots around the edge on both of them..
