820 Pony motor thrown a rod?
SAm
07-22-2003 12:56:00
I helped someone remove the waterpump from the Pony motor of their JD 820 this morning because they had discovered water was getting into the oil and they thought it may have been getting in through the water pump. After we got the pump out I discovered the mangled remains of the crankshaft end of a piston rod. We traced this to the front right cylinder. Apparently the engine had seemed to be running fine though. As we haven't got access to a parts manual had have little knowledge of this particular tractor I am hoping to recieve suggestions and instructions on how best to repair this and remove the pony motor (presumably it has to be removed to fix the problem) also any good sources for parts. Thanks, SAm
F-I-T
07-22-2003 13:39:18
 Re: 820 Pony motor thrown a rod? in reply to SAm, 07-22-2003 12:56:00
Sam:
Well, there is the extreme posibility that someone left a fragment in there from a previous repair, and the engine did truly run just fine, but I doubt it.
Did you check the compression ? Even putting you finger over the open plug hole would show it up.
You're going to want to get at least an I&T book to guide you through that pony, because once you tear it down for the rod, you'll want to most likely pull the sleeves out to clean the rust and crud in the water jacket area, clean all the oil return holes, replace the rear seal, probably re-face the clutch, the tranny brake, and grind the valves. While the pony transmission is apart, you should inspect the over-running clutch to be sure it's not worn grooves in the star driver.
I haven't found any aftermarket parts for the ponies. John Deere does still offer the gaskets, rods, rings and pistons. They're pricey, but better than not being able to get them at all.
You'll want to lift the pony off the main engine, because you access the bottom end through a plate under the engine.
It can be lifted on and off by a couple of guys, but I prefer my engine hoist, so you might want to plan on that in where you park the 820.
Frank-in-Tallahassee
70D // 855
SAm
07-22-2003 23:29:13
 Re: Re: 820 Pony motor thrown a rod? in reply to F-I-T, 07-22-2003 13:39:18
The front right piston is definately not connected to the crankshaft any longer as it can be pushed up and down the cylinder. Are the IT manuals available through JD? Also, should parts for an 820 be available through any JD dealer as this one is in the UK. Thanks, SAm
F-I-T
07-23-2003 04:33:52
 Re: Re: Re: 820 Pony motor thrown a rod? in reply to SAm , 07-22-2003 23:29:13
SAm:
Yes, I believe any parts that are available will be available in the UK as well. The I&T books are a condensed version of the service manual produced by an independent company. You might find one on e-Bay.
Since you are working on this in the UK, and your dealer may not be so familiar with the machine, the best thing to do would be to buy the actual Deere service and parts books for the 820. That way you might be able to help the dealer help you since you will be looking at the same reference material. That, in combination with postings here, should get you the most cost efficient repair.
You can order the manuals for the 820 by calling Deere direct at 800-522-7448. The Service manual for the 820 is SM2021, and the parts catalog is PC766.
Frank
Tim
07-22-2003 19:02:12
The pistons are no longer available from deere but the rings and the some gaskets are. Just recently when to buy a set of pistons and they are absolete as my JD dealer told me but Greg Stephens has them.
F-I-T
07-22-2003 19:16:50
 Re: Re: Re: 820 Pony motor thrown a rod? in reply to Tim, 07-22-2003 19:02:12
Tim:
They still show as an active number on JDParts.com. $275.10 each for F1810R which is the bare piston.
Your dealer might not have looked hard enough. There is a separate number for the piston versus the piston/rings assembly. It's in the description verbage.
Frank
Frank
Matt
07-22-2003 16:42:08
IS the 820 pony motor the same as what is on the 70 and 720?
Thanks
F-I-T
07-22-2003 17:41:47
 Re: Re: Re: 820 Pony motor thrown a rod? in reply to Matt, 07-22-2003 16:42:08
Matt:
For all intents and purposes. On the 80/820/830/840, the transmission is different, and the later ones had thermostats, but the internals are pretty much the same.
F-I-T
Farm w/Junk
07-22-2003 17:08:02
Hi I am not sure if they are the same I am thinking they are though. But I have a complete pony motor I may sell It runs good just needs the carb rebuilt or cleaned. We hauled the tractor home and now it will start but not rev up. Which leads us to believe something splashed around into the carb.I am in Norhtwest Ohio. Make me an offer.
Matt
