JD 50 acting funny
jason r
07-22-2003 08:01:20
i bought a jd 50 a couple of weeks ago and it is acting funny after it is warmed up a bit. when it first starts the tractor is real quiet and makes no noises. after about 10 minutes of running/driving it begins to have a knock. it seems to be coming from under my feet. sometimes it goes away and shows up depending on the angle the tractor is sitting. i had a 46 b that had the 1st reduction bearing go and it made the same kind of noise. this one feels the same but i can't detect any real vibration from under that cover. does anyone have any ideas as to what it might be? any help or suggestions would be helpful. the knock also occuse when the clutch is engaged and the tractor is in neutral....the feeling goes away when you drive it. the motor has good compression and oil pressure....so it leads me to something other than that. thanks.....
mark
07-22-2003 13:30:48
 Re: JD 50 acting funny in reply to jason r, 07-22-2003 08:01:20
check your flywheel bolts. If the flywheel is loose it will knock as described.
