JD 1951 B - Question on permatex?
phil
01-15-2004 10:50:00
Got an oil leak, so I am replacing the valve cover gasket on my 51 B. The dealer had it in stock so it must be an 'often replaced' item. Should I permatex the new one or should I put it on 'clean'?
John T
01-15-2004 16:49:43
 Re: JD 1951 B - Question on permatex? in reply to phil, 01-15-2004 10:50:00
Phil, the best luck Ive had over the years on the part you mentioned or on about any valve covers is to FIRST stick (with Permatex) the gasket onto the removable part like the valve cover and let it sit n dry, maybe even a day. That way when you snug down the valve cover, the gasket dont squeeze out of place or distort etc. Just before replacement, I use something like non hardening Permatex, a very light film on the head surface making sure all was clean smooth n dry. If you're sure youre gonna remove it to re set the valves, I wouldnt use anything the first time on the head, however, and then non hardening permatex on the last seal down.
I dont think Ive ever had any leaks when I did it that way. Hopefully, you will get plenty other opinions of what has worked for others, that way works well for me.
Best Wishes n God Bless ya Phil
John T Nordhoff
Clooney
01-15-2004 13:34:05
Phil, I usually use 3M super weather strip adhesive on the cover side to glue the gasket to the cover & keep it from shrinking or moving during installation, then use a light coat of regular chassis grease on the head side.. That way the cover is removable to do a re-torque or valve adjustment at a later time & the gasket will be re-usable.. After about the second removal & re-installation I clean the gasket [head side] with brake clean & when it dries use a light coat of #3 Permatex on it, then that would be the last time I use it [been doing it that way for years]..... ..
[email protected]
Jack
01-15-2004 12:04:15
Those cork gaskets soak up quite a bit of oil & usually seal well, provided the mating surfaces are clean. I never use any on mine
