D Flywheel End Play Adjustment
cheg
07-21-2003 20:26:03
Should the clutch be engaged or disengaged when checking and setting the flywheel end play?
What is a safe way to move the flywheel in without breaking something?
Thanks
Clooney
07-22-2003 03:32:16
 Re: D Flywheel End Play Adjustment in reply to cheg, 07-21-2003 20:26:03
Cheg, the clutch engagement position doesn't have any effect on the crank [flywheel] end play as the clutch pulley moves with the crankshaft.
~There are a couple of ways to move the flywheel in on those old D's to reduce end play.
~The safest way is to remove the clutch cover [3-bolts] , then loosen the flywheel pinch bolts, then have someone hold the crankshaft all the way in towards the left using something heavy [like a big 15# hammer] against the crankshaft center bolt inside the clutch pulley, then use a block of wood & a hammer to drive the flywheel in [towards the right] until the proper .005� to .010� end play is achieved. The problem is that takes 2 people.
~What I usually do [on the D] is use a long board & prop it between the R/H rear tire & the clutch cover [clutch must be engaged] with a rag between the board & the clutch cover. The board extends forward from behinds the R/H tire & across the pulley cover, then I use a rope & tie the board off to the engine manifold. That will keep pressure on the crankshaft & hold the crankshaft in to the left & allow one person to drive the flywheel in.
~There are other ways to get the job done also, but those are the two I usually use. The idea is to hold the crankshaft to the left while you drive the flywheel to the right. Flywheel position on the crankshaft controls crankshaft [flywheel] end play�
