Brush Hog lubrication question
DMack
07-21-2003 12:38:15
Hello,
I just bought a FMC SX-50 brush hog for my JD40. On the gearbox, there is a plug on the back and a small allen socket plug (fill and level holes, I assume) and a single fill plug on the top of the front gearbox housing. My question is what kind of lube and how much do you put in each opening? I added 90 wt gear lube in the rear housing up to the level plug, but it leaked out by the main shaft underneath. I therefore assume that either it takes grease or a seal is shot.
Any help you can give me would be greatly appreciated.
Dave
Henry J
07-21-2003 19:48:03
 Re: Brush Hog lubrication question in reply to DMack, 07-21-2003 12:38:15
DMACK
Another alternative i would consider is using corn head grease sold in tubes at the jd dealer in the gear box, since it appears that the lower seal is worn
Robert
07-21-2003 14:37:27
I have an old FMC brush hog/mower that sounds like it has a gearbox similar to yours. When I got ready to use it, I pulled the front plug, and added oil at the back of the gearbox (upper plug) until the front was full. I used gear oil to fill it.
I then also added a vent to the upper plug so that any vapor pressure created by turning would have a means of escaping, rather than creating pressure in the gearbox, which might cause a seal leak.
Hope this helps!
DMack
07-21-2003 17:31:53
 Re: Re: Brush Hog lubrication question in reply to Robert, 07-21-2003 14:37:27
Robert,
Thanks for the tips.
Dave
Robert
07-22-2003 09:29:20
 Re: Re: Re: Brush Hog lubrication question in reply to DMack, 07-21-2003 17:31:53
You're more than welcome. I hope your mower works as good for you as mine has for me.
Good Luck!
John T
07-21-2003 13:02:29
Mack, Personally, Ive never owned a bush hog that DID NOT leak out the bottom shaft seal to some extent, although Ive never owned a new one either. I always run like 85W140 or 90W140 (forget which is sold???) or even straight 140 (just whatever happens to be in my shop) cuz it takes much longer to leak out and lubricates plenty well enough and I never use it in the winter anyway where I may have to worry the oil is too thick. All those bevel gear gearbox bush hogs with the top fill plugs and side fill level indicators Ive ever owned used 80 up to 140 W Gear Oil instead of just hard grease.
John T Nordhoff
DMack
07-21-2003 14:12:17
 Re: Re: Brush Hog lubrication question in reply to John T, 07-21-2003 13:02:29
Thanks John,
on the front housing there is only a fill plug on the top of the housing-no fill level hole. How much lube do you generally put in?
Thanks again,
Dave
