Clooney - others HELP! JD B Clutch disassembly
RayP(MI)
07-21-2003 07:10:53
I'm the poster with the broken operating bolt, in need of replacement on a '49 JD B ser# 2578**. I am trying to remove the drive disk on the clutch. Am unable to pull it off the crankshaft. Manual showed removal using two 1/2 inch bolts. I am assuming that they are threading through the disk, and pushing against something internally to push the disk off. Tried that, and ended up breaking off one of the bolts in the hole. Tried a gear puller against the loostened bolt that goes into end of crankshaft. No luck there, and ended up breaking a chunk off the edge of the drive disk. I'm at my wits end - I'm going to destroy the whole tractor before I'm done. How do I get the drive disk off? Diagrams JD93 and JD97 in I&T shop manual (pg 28 & 29)
Clooney
07-22-2003 03:44:37
 Re: Clooney - others HELP! JD B Clutch disassembl in reply to RayP(MI), 07-21-2003 07:10:53
Ray, it looks like you received some good advise below, I can't add much. ~On that broken drive disk? Depending on how big the area is that is broken.. You can use a soft cast iron rod & re-weld [build up] that broken area then grind it or file it back to shape. You could probably find a local welder to weld it pretty cheap if you do the grinding & filing yourself.
RayP(MI)
07-22-2003 05:21:10
 Re: Re: Clooney - others HELP! JD B Clutch disass in reply to Clooney , 07-22-2003 03:44:37
Thanks Clooney, I welded it up myself. Put the chip back in, and tacked it at the edges, then took my Dremmel and ground a small groove along the joint. Then I welded it with a wire welder with mild steel wire. Then ground the weld down smooth with the Dremmel and die grinder. Think it will work, although the clutch may be a bit "grabby" for a while! It shouldn't be a high stress point, and that wire welder makes even me look good! CAN YOU BELIEVE THE LUCK OF HAVING A BOLT LIKE THAT IN STOCK? The old "B" we usta farm with left in the early '70s, and there are probably not ten pieces of spare JD parts on the farm, - so to have the one I needed....!!!!
RLA
07-21-2003 10:05:37
I believe your going about it the wrong way? On the 49 B I owed the 1/2 inch theaded hole didn't go all the way thru the driver. I used a cross bar made from plate steel. Removed the center bolt, then screwed it back into the crank without the large washer to protect the thread. Then used a specer between the plate cross & the center mounting bolt. Screwed in the 1/2 pulling bolts to where they had good even pressure on both sides. A block of hard wood & 3 pound hammer dead center on the plate cross bar should do the trick.
Now you need to drill out your twisted off 1/2 bolts, & use this method. You'll also need to find another driver, for balance will be off it there's a broken off.
RLA
RayP(MI)
07-21-2003 12:31:49
 Re: Re: Clooney - others HELP! JD B Clutch disass in reply to RLA, 07-21-2003 10:05:37
RLA - you're right - I just finished up doing a modification of your procedure. Was able to drill out broken stub, and easy out it. Got a socket from the socket wrench set that just fit in the splined hole in center of drive disk. Fabricated a plate with two 1/2 inch holes same width as holes in disk. Used a couple pieces of 1/2 inch threaded rod threaded into holes, and then put washers and nuts on plate side. Impact wrench and just a couple light bumps on the snugged up nuts, and off it came. I cannot for the life of me figure out why it wouldn't come off with a gear puller. I'm going to see if I can repair the chip in the disk. Also, found a operating bolt in the junk box in the barn, rethreaded it, and it looks like it'll do the job! We had an '47 B on the farm from new to about '70. Why that ghost part still remains, I'll never know - but for $47.51, I'll gladly use it!
RLA
07-21-2003 10:04:51
RLA
