Injection Pump Advise Needed
Dave in Michiga
07-21-2003 03:02:10
We have a 1974 301A 3 cylinder diesel that runs great for about 15 minutes and then just dies. Information we have gathered leads to a definite fuel problem. We have removed and cleaned the fuel tank, lines, (inlet and return), and replaced the filters. The fuel supply to the injection pump seems good, so this leaves the injection pump itself. The question now becomes, is this a project we should do ourselves or is it better to bite the bullet and pay the big bucks to have it done. The manual on the pump list some special service tools, but are they really needed? All our experience is in gas vehicles, but the laws of physics don't change. Any advise or direction would be most appreciated. You guys are the real experts!
Bob
07-21-2003 08:03:28
 Re: Injection Pump Advise Needed in reply to Dave in Michigan, 07-21-2003 03:02:10
Run it with the return line disconnected from the pump. Plug the FUEL TANK SIDE of the return line and rig a temporary return line from the check valve fitting to a catch container. (IN A SAFE MANNER TO PREVENT SPILLED FUEL/FIRE) (The spring loaded glass ball is a HOUSING PRESSURE REGULATOR) You can even try running it with the fitting removed from the pump. (Use a nipple and a hose to direct the fuel away safely)
Does it run with the return line opened up? If it does run, you have a restricted fuel return line, or a gob of the governor dampner ring floating around in your pump, which ocasionally blocks the return port.
If it DOES NOT keep running, you may have fuel supply problems. Is the engine shutoff electric or a manual cable you pull to shut it off?
Dave in Michigan
07-21-2003 08:18:26
 Re: Re: Injection Pump Advise Needed in reply to Bob, 07-21-2003 08:03:28
This pump has an electric shut off solenoid. Can we damage something by running the unit with the pressure regulator removed?
Bob
07-21-2003 12:29:12
 Re: Re: Re: Injection Pump Advise Needed in reply to Dave in Michigan, 07-21-2003 08:18:26
You will not damage anything running it for a few minutes to verify if it will keep running.
davidval
07-21-2003 06:48:48
from your description there is high probability that the fuel return from the pump is blocked, as mentioned in other posts, thus forcind too much advance and killing the engine. the blocking is coming from a plastic coupling within the pump that is falling apart.
you can disconnect the return line at the pump, run the engine and see weather engine drop in rpm corresponds with stop of flow from the pump at the return.
if it does, you can remove the adapter from the pump (this is the valve mentioned in other posts) and you will probably see the pieces of darkened plastic.
in this case, of course, you have to repair the pump.
david
Jim B
07-21-2003 05:39:06
Dave,if you can kill it by turning off Key the elect. valve in pump could be cutting fuel off because of shorting or lose of elect.Plunger in it can be removed and it will start but you will have to cut off air or put in high gear /hold brakes to kill it.It a test you could do before removing pump.Also Cannonball is right on about check valve in return line as I have seen several of those stopped up with rubber from ring in pump.Also if pump needs rebuilt I would leave that to a pump repair place.Always use caution when working on machinery(disclaimer)Jim B
cannonball
07-21-2003 04:37:38
make sure that the little check valve on top of injector pump on return line is not stopped up...also have you changed fuel tank caps..just some thoughts...have nice day may god bless
Dave in Michigan
07-21-2003 05:57:23
 Re: Re: Injection Pump Advise Needed in reply to cannonball, 07-21-2003 04:37:38
We have changed the check ball on the return line at the pump and it seemed to run longer before stalling. What is the purpose for the check ball in the return line? Is there a way to clean the valve? It seemed to be a glass ball in the fitting. There was nothing visible that would prevent flow but the fitting had a great deal of restriction.
Mark Scholten
07-21-2003 04:16:26
Dave:
If you are certain the problem is in the pump, take it to a diesel injection service shop. Let me know where you are located and I may be able to give you a name of a good shop in your area. But 1st, check any elbows that go into the filter housings. I have seen all too often, pieces of cardboard stuck in the ells and they let some fuel through for a short time and then they start to starve. Any other questions, give me a hollor. I've been working on gas and diesel engines for over 30 years and have not seen or done it all but maybe I have seen or done what you have.
Mark in Sparta. (By Grand Rapids.)
Dave in Michigan
07-21-2003 05:40:05
 Re: Re: Injection Pump Advise Needed in reply to Mark Scholten, 07-21-2003 04:16:26
We are located near Midland, Clare and Mt. Pleasant. Is there a test or something I can perform to make sure it is the injection pump causing the problem? You guys are the greatest!
